Author: Subject: Wanted: Pinto Fuel Pump Push Rod
mkeats02
posted on 18/7/12 at 12:21 PM Reply With Quote
Hi
I am after a push rod for the pinto mechanical fuel pump, I need the part that fits just inside the block as the shaft on the pump itself is not long enough to pump when the engine turns over.
Mike
This Monkey's gone to Heaven
Thruth does not exist, it is only Human Opinion
James
posted on 18/7/12 at 01:13 PM Reply With Quote
I couldn't find one easily either. Someone sent me a CVH one which is about twice as long as you need but I cut/turned this one down and have had no trouble with it.
HTH,
James
scoop
posted on 18/7/12 at 04:17 PM Reply With Quote
I've got one
PM me to sort out.
