Author: Subject: Help!!!
RJK350
posted on 17/3/13 at 09:46 PM Reply With Quote
Help!!!
Our local council has carried out a cheap road surface. Covered the road in tar and put chippings down.
Apart from the stone chips, what's the best thing to get tar off the body work?
It's good to know your taxes are being put to good use
maccmike
posted on 17/3/13 at 09:56 PM Reply With Quote
petrol
madteg
posted on 17/3/13 at 09:57 PM Reply With Quote
WHITE SPIRITS
RJK350
posted on 17/3/13 at 09:58 PM Reply With Quote
Thanks guys
umgrybab
posted on 17/3/13 at 10:07 PM Reply With Quote
acetone works very nicely.
morcus
posted on 17/3/13 at 10:13 PM Reply With Quote
Basically, any solvent. Personally, White spirit and a roll of cleaning rag, dip the rag and rub it in little circles.
perksy
posted on 17/3/13 at 10:21 PM Reply With Quote
White spirit or WD40
martyn1137
posted on 17/3/13 at 10:26 PM Reply With Quote
Autoglym intensive tar remover. Spray on wash off.
NigeEss
posted on 17/3/13 at 10:54 PM Reply With Quote
Brake cleaner.
posted on 17/3/13 at 11:04 PM Reply With Quote
X2 works very well indeed.
Once it's off, a really good coat of wax helps stop fresh tar sticking quite so much too.
Our road was done this time 2-3 years ago, same thing, spray poo loads of tar everywhere, dump a load of chippings and bugger off. I complained enough times to the council they came round and swept the road twice then dusted it to try and deal with the excess tar. The road is still a bloody mess every summer when it bubbles and peels. There was nothing wrong with it before
posted on 17/3/13 at 11:19 PM Reply With Quote
Don't use acetone it is deadly to a lot of paint finishes.
A kitchen wipe dipped White spirit, kerosene, derv, Swarfega or even butter, works well followed by wax polish. Mr Sheen or similar would also work.
If I suggested petrol somebody would point out it contains Benzine which is a nasty.
designer
posted on 17/3/13 at 11:30 PM Reply With Quote
WD40
Mr Whippy
posted on 18/3/13 at 12:19 AM Reply With Quote
I got their wipes that do a very good job too
jossey
posted on 18/3/13 at 08:11 AM Reply With Quote
Taking pics of it and contacting ye council too. Bug n tar remover works but not as easy as acetone...
David Johnson
