Author: Subject: Under bonnet heat
carlknight1982
posted on 21/4/13 at 09:32 PM Reply With Quote
Under bonnet heat
Has anyone used anything under there bonnet to keep temps under control
[Edited on 21/4/13 by carlknight1982]
Logic will get you from a A to B
Imagination will take you everywhere.
MsD
posted on 21/4/13 at 09:44 PM Reply With Quote
My exhaust manifold is wrapped and I've got some of that flexible self adhesive hear shield to stick to the underside of the bonnet. I havnt used the car in anger so can't comment yet!
Mark.
zetec
posted on 21/4/13 at 09:47 PM Reply With Quote
Good airflow is the best method of keeping heat down.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
carlknight1982
posted on 21/4/13 at 09:53 PM Reply With Quote
I'm just thinking of a " belt and braces" approach
DavidM
posted on 21/4/13 at 11:48 PM Reply With Quote
I have the exhaust manifold wrapped and also have a vent in the side panel on the exhaust side to encourage airflow past the manifold and out of the engine bay.
[img] Scuttle 2008
Scuttle 2008
[/img]
[Edited on 21/4/13 by DavidM]
Proportion is Everything
snapper
posted on 22/4/13 at 05:36 AM Reply With Quote
I've propped the rear of the bonnet open by 5mm
Double wrapped the manifold, heat shields by the master cylinder and for the rear off the alternator after frying 2
I eat to survive
I drink to forget
renetom
posted on 22/4/13 at 06:47 AM Reply With Quote
We did this
Seems to work fine.
Bonnet Vents both sides
40inches
posted on 22/4/13 at 07:16 AM Reply With Quote
Side and bonnet vents.
Vents
Vents
welderman
posted on 22/4/13 at 09:26 AM Reply With Quote
Im hoping when i do mine out of ally, going to put loads of luvers in like a catering van one
Thank's, Joe
I don't stalk people
pewe
posted on 22/4/13 at 10:20 AM Reply With Quote
I've mounted an oblong section of fire-proof soffit board above the header pipes.
It's a bit like asbestos board and available from local builders merchants for next to nothing in 2-3 mtr strips.
At the same time I bought a couple of big spring tool clips, bolted them through the board so they correspond to the front and back pipes, then slide the clips over the pipes.
That way the board is easy to remove if necessary.
Even though the headers are wrapped it shows how much heat they generate as the board lasts about a year/18 months before the heat degenarates it.
An extra packing piece of board between the clips and board seems to dissipate the heat better so the board lasts longer.
HTH.
Cheers, Pewe10
bi22le
posted on 22/4/13 at 12:02 PM Reply With Quote
I have a large CBS vent above the headers and a peice of heat reflective sheet underneath. This seems to help chuck a lot of heat out of the vent and I can see this when I have stopped. Vents at the back of the bonnet help over cam cover heat and keep radiator flow high, as do side wind deflectors going forward on the rad. The side wide deflectors on the rad stop air going through the nose, hitting the radiator and flowing round the sides, a must have in my eyes. The after rad air is then helped to flow \ exit through side vents and not try to be forced down the transmission tunnel. I also have a ali heat sink thing on my oil filter to suck air out of it and a cold air feed to said heat sink. On hard 30 min track sessions my water temp is good but I will see 140deg+ on oil so I use high quality race oils to make sure they can handle this.
My only worry is the oil temp which I may try to solve with an oil rad. I already have an oil to water exchanger at the oil filter, not sure how much this helps.
Please read my ring story:
