Author: Subject: Bonnet/Nose vents
Worzey
posted on 2/5/13 at 02:38 PM Reply With Quote
Bonnet/Nose vents
Following my post yesterday concerning cooling issues I'm looking for suggestions on solutions for shift air out from under the bonnet.
Looked at NACA ducts which look cool but not sure how effective they'll be at removing heat. Likewise a nose mounted scoop might look nice but will it vent?
I'd love you to post pictures of what you've done so I can consider options. Did you make them yourself or source elsewhere?
Caterham R400
40inches
posted on 2/5/13 at 02:59 PM Reply With Quote
Nose cone, bonnet at rear and side panels.
Vents
Vents
Ben_Copeland
posted on 2/5/13 at 03:04 PM Reply With Quote
Bonnet Vent
Bonnet Vent
Bonnet
Nosecone
Ben
Locost Map on Google Maps
Enter Your Details Here
Worzey
posted on 2/5/13 at 03:05 PM Reply With Quote
How did you fix the grill on the nose cone? Glued?
Caterham R400
Ben_Copeland
posted on 2/5/13 at 03:22 PM Reply With Quote
Glue. Best to use sikaflex.
Ben
40inches
posted on 2/5/13 at 04:15 PM Reply With Quote
I bonded ally angle to the return on the lip, and used screws and big washers.
wicket
posted on 2/5/13 at 04:21 PM Reply With Quote
Glassed in some wire loops and used tyewraps; been there 7 years now with no problems
tomgregory2000
posted on 2/5/13 at 04:53 PM Reply With Quote
Ummmmm
You don't want or need any bonnet vents ducting air in
You need holes in the bonnet to let the air out
tomgregory2000
posted on 2/5/13 at 04:55 PM Reply With Quote
Car 8
Car 8
Here is a picture of my vents I cut in my bonnet and its surprising how much hot air came out and I had a turbo sat in the nine bay, my exhaust was wrapped as well
posted on 2/5/13 at 05:57 PM Reply With Quote
Yep, getting the hot air out from the engine bay behind the rad not getting cool air in is the objective.
NACA ducts are very efficient as inlets but don't really work as extractors.
Like tomgregory2000 car extractor vents at the rear sides of the bonnet work really well
Here are a 1950s examples on a Austin Champ
Worzey
posted on 2/5/13 at 06:11 PM Reply With Quote
Thanks for the replies. Looks like it'll be a job for a hole saw, dremmel and wire mesh . Hopefully the second rad fan will control the overheating but vents will help and look pretty cool.
Caterham R400
