Author: Subject: scuttle
Hopley89
posted on 24/6/13 at 11:11 AM Reply With Quote
scuttle
hi all whats the best way to make my scuttle ? has anyone made there own . if so any tips ?!
all help would be brilliant
thanks dan
40inches
posted on 24/6/13 at 12:45 PM Reply With Quote
thanks dan
The best way to make a scuttle? buy one
RK
posted on 24/6/13 at 01:02 PM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=111433
or if you prefer
http://www.locostusa.com/forums/viewtopic.php?f=23&t=1033&view=next
[Edited on 24/6/13 by RK]
mark chandler
posted on 24/6/13 at 03:14 PM Reply With Quote
I made a former from mdf, then bent the aluminium around this and dressed the edges down so it kept its shape then welded up.
Could have also riveted it together easily enough then added a separate rebate for the bonnet to lay upon.
The advantage for me was keeping the bodywork as low as possible in the car, disadvantage is that if you want a full size screen it may not fit your curves, I drew around an old paint pot
Ali bulkhead
Ali bulkhead
Oh, it's cheap
Hopley89
posted on 24/6/13 at 03:45 PM Reply With Quote
hi mate cheer for the reply ... im going to make the mock up tonight in ply ..
and im not haveing a windscreen so i should be ok
dan
