rucksak
posted on 23/11/13 at 08:45 PM |
Paint Stripping Aluminium
Hey, does anyone know the best method of removing paint from aluminuim, i want to do some repairs and repaint my bonnet, would paint stripper be any
good or is it possible to get the bonnet shot blasted.
mark chandler
posted on 23/11/13 at 09:11 PM |
Paint stripper, give it to a blaster and if they use high pressure or corse media the bonnet becomes scrap.
rucksak
posted on 23/11/13 at 09:22 PM |
What would be the best paint stripper to use, could some makes damage the aluminium
Staple balls
posted on 23/11/13 at 10:29 PM |
Nitromors used to be fine on aluminium.
I'd use that ancient tin from the back of the shed though, the newer stuff is rubbish. ![](/images//smilies/bigsmile.gif)
bimbleuk
posted on 24/11/13 at 04:40 AM |
If the paint isn't some baked on finish then Nitromors should be OK
120 grit flap disc in a small grinder will also do it. There's also Polycarbide discs designed for removing rust/paint. Not tried those yet
myself.
Media blasting would be the easiest, soda or fine crushed glass shouldn't ruin the ally.
posted on 24/11/13 at 08:54 AM |
Indeed, modern Nitromors is even safe to use on painted surfaces
[Edited on 24/11/13 by MikeRJ]
Ashley Jenkins
posted on 27/11/13 at 02:30 PM |
i recently used some of the ploy carbide discs in a 4.5'' angle grinder when stripping three or four layers of paint of my land rover
wings with very good results. I have used nitromors in the past but found it very messy and time consuming.
ianm67
posted on 27/11/13 at 02:59 PM |
Heat gun and a 'soft' plastic scraper of some type?
Always biting off more than I can chew.....
jps
posted on 27/11/13 at 03:27 PM |
I used some of this a couple of weeks ago - to strip paint from an old pub sign - 3mm alu and no idea what kind of paint but it had fared well in the
great outdoors for years. Only £6 for the 1ltr bottle and I still have about 200-300ml left after putting a couple of coats on
http://www.diy.com/nav/decor/decorating-supplies/treatments-cleaners-protection/treatments/-specificproducttype-paint___varnish_remover/B-and-Q-Paint-
and-Varnish-Remover-1L-12599096
Pics of it before : http://meandthekitcar.wordpress.com/2013/08/18/floored-pt-3/
and after : http://meandthekitcar.wordpress.com/2013/11/10/random-progress/
I did leave it to 'soak' for a long time - but it worked very well.
