Author: Subject: Side Panels
Dick Axtell
posted on 29/10/04 at 04:46 PM Reply With Quote
Side Panels
Am presently working on a card template for the side panels. After much fiddling, I've managed to make suitable apertures for the wishbones and track rods. All this time-consuming fiddling has given rise to a question.
Do I go for the one-piece side-panel, or the as-per-book 2-piece version?
What did other builders achieve on this area of the build?
And how?
TIA
[Edited on 29/10/04 by Dick Axtell]
posted on 29/10/04 at 04:56 PM Reply With Quote
I didn't go as far as the nosecone, I stopped at the fu section, westy style. It lets the air flow through the radiator better and is easier for maintenance if you need to get to the rack etc. I did mine in 2 pieces as it was more economical, but I'm doing it in 1 next time.
Ben_Copeland
posted on 29/10/04 at 05:02 PM Reply With Quote
Yep, didn't bother going all the way, just up to rear wishbone mounts (fu1/2 tubes i think)
Makes access easier to rack, be a bitch to do anything otherwise.
Ben
Locost Map on Google Maps
Enter Your Details Here
theconrodkid
posted on 29/10/04 at 05:22 PM Reply With Quote
it gets a bit hot under the bonnet so best have as much air flow as poss
who cares who wins
pass the pork pies
splitrivet
posted on 29/10/04 at 05:24 PM Reply With Quote
Same here went up to FU's then made a smaller panel to cover the wishbone area.
Bob
scutter
posted on 29/10/04 at 07:45 PM Reply With Quote
Same as above took mine to the FU tubes, believe it's the same as MK build them.
ATB Dan
side panel outside
side panel outside
side panel inside
side panel inside
zetec
posted on 29/10/04 at 09:02 PM Reply With Quote
Mine go right up to the nosecone (earlier MK) and no probs with overheating. To gain access to the rack (which must be rare) just take the nosecone off.
Dick Axtell
posted on 30/10/04 at 08:15 AM Reply With Quote
Guys,
Many thanks for the +ve feedback.
Scutter, those pics are very useful.
scutter
posted on 30/10/04 at 08:52 AM Reply With Quote
Glad to be of help
ATB Dan.
