Author: Subject: Argh!!!! Dislodged clutch release arm, need to pull engine!!
DanP
posted on 21/6/15 at 07:47 AM Reply With Quote
Absolutely furious with myself... Was just finishing up refitting sump after pulling it to weld a hole I put in it last year, was trying to get as much clutch pushrod shaft as possible into the clutch slave and ended up pulling the release arm off the mounting meaning I have to pull the whole engine and split the engine/box to put it back together again!!!
I was minutes away from being back on the road now I'm weeks away!!!
Aaaaaaaaaaarrrrrrrrrrrggggggggggghhhhhhhhhh!
Benzine
posted on 21/6/15 at 07:58 AM Reply With Quote
Been there done that engine out and back in within 2 hours though, have you got a crane?
DanP
posted on 21/6/15 at 08:19 AM Reply With Quote
Yes thankfully, bitten the bullet and started pulling!
Irony
posted on 21/6/15 at 12:48 PM Reply With Quote
That's an issue on the viento. I reckon my reverse gear is dodgy but it means taking the engine out. Which is easy to on the viento but still a days work!
DanP
posted on 21/6/15 at 01:01 PM Reply With Quote
6 hours later it's out.... Good time to change the clutch as I reckon it slips a little and change the box oil. Oh and clean the engine bay, and repainted the Engine.... Because it is not coming out again any time soon!!!
jollygreengiant
posted on 5/7/15 at 06:01 AM Reply With Quote
Been there, done that. Spent a day one (in a garage) changing the clutch on a Sportrak (Diahatsu), whilst tidying up I found a spring that held to release bearing onto the arm. DOH. Gearbox out, fit spring, refit box, just under 2 hours. It's surprising what you CAN get done when time is an issue.
owelly
posted on 5/7/15 at 12:52 PM Reply With Quote
Late one night I started to change the clutch in my Minivan. By about 4am I had it done so jumped in, turned the key and started the engine. Then noticed the new clutch in the passenger footwell........
http://www.ppcmag.co.uk
Angel Acevedo
posted on 5/7/15 at 02:58 PM Reply With Quote
Made me cry...
From laughter...
Has happened to me with smaller stuff...
