Author: Subject: Westfield wide bodied zetec for sale
Shaggydoo
posted on 13/6/16 at 11:24 AM Reply With Quote
After a bit of time away from the sprint scene, another baby, marriage, less time and money available. I have concluded the Westfield SEIW has to go up for sale.
She is in good condition and cleans and polishes up very nicely, as the pics indicate albeit she is not a show car and there are a few age-related scratches and blemishes from clumsy kids in the garage, marks and stone chips.
The car is very well balanced with good power, which makes it a joy to drive both on road and track. I've owned the car for almost 4years and the only failure i had was a broken throttle cable and a weak detent spring which was a simple fix.
Having taken ownership of my Westy i was keen to get onto the track and really enjoy the car without worrying about speeding fines. While at the wscc Blyton weekend and trackday, my eyes were opened to the world of sprinting.
The following year I made a few mods and entered my first sprint, I was then hooked and wanted to do more. So even more mods and a better setup, i did a full season.
After a great years competition we managed to achieve a 2nd place in the WSCC novice sprint championship, learned tonnes, (low 64sec @ Harewood) had loads of fun doing it and made some great mates in the process. While i would like to get back into another seasons sprinting next year, (subject to new rules:-) I just don't think i can afford it.
Car has a big folder showing lots of history and receipts
Detailed spec as follows:
.Registered 2005 (55 plate)
.Colour – White with Black nosecone
.Current mileage – 18000(as of March 2016)
.MOT - 10 months (passed 2016. No advisories)
.Running a interchangeable aero screen, windscreen and doors inc
.Full tonneau cover
.MSA roll bar
Engine Bay
.2.0 Zetec (Blacktop) – Raceline 200 spec
.ARP bolts
.Raceline RL200 cams
.Raceline cylinder head, ported and polished
.Jenvey 45mm throttle bodies, linkage and fuel rail
.Jenvey wiring loom
.Jenvey 90mm trumpets
.Bosch injectors
.Raceline lightened flywheel
.Raceline lowline alloy baffled sump
.Upgraded engine mounts
ECU
.Mbe 967e fully programmable ECU
Cooling
.Hi torque starter motor
.Radtec aluminium high capacity radiator
.Raceline water rail
.Silicone hoses
.No overheating or overcooling issues
Induction & Exhaust
.Wunoff repackable silencer
.Pipercross air filter
.Raceline 4-to-1 exhaust system
.Acoustafill silencer packing
Gearbox / Diff / Drive
.SP Comp - 'Rocket ratio' semi helical Type 9, 5 speed gearbox
.Ratios 2.48, (long 1st), 1.61, 1.22, 1, 0.87.
.Westfield alloy short lever
.Comp Alloy bell housing
.Limited slip differential, 3.92 ratio
Power / Output
. Daytuner extensively set up on rolling road, all figures were measured at the wheels. 175bhp @ 7250rpm and 153ft/lb torque @ 5500rpm 200+@crank
. Weight 540kgs
Body
.Diamond white with black nosecone. (There are a few light scratches and stone chips)
.Carbon mickmade front splitter
.Csr type carbon front cycle wings (mounted with hidden bighead fasteners)
.Carbon Mods carbon dashboard
,Carbon Mods carbon rear arch protectors
.Carbon Mods carbon kick strips
.5" headlights
.Small motorbike indicators
Interior
.Westfield race seats, on runners (Driver)
.Westfield 4-point harnesses
.Momo suede D race steering wheel
.Rapfix quick release steering wheel boss
.Odyssey PC680 gel battery
.12v power supply (ideal to run a trickle charger to)
Brakes
.Hispec 4 pot calipers (front)
.Mintex 1144 pads (front)
.Grooved disks (front)
.Pagid pads (rear)
.Dot 5.1 brake fluid
.Brake lines (braided)
.Floor mounted pedal box
Fuel
.Aluminium Westfield injection fuel tank with sump (28 litre)
.Facet fuel pump
.Webber 3.0bar fuel regulator
Handling
.Quickrack
.Playskool front and rear anti roll bars
.Avo adjustable dampers and springs
.Polybushes all round
.Genuine westfield wide track suspension
.new rose joints and track rod ends
.Westfield aluminium front hubs
.Westfield rear alloy uprights
.Blink full geometry set up and corner weighting. Set up for fast road/track
Wheels & Tyres
These are high quality lightweight German made ATS dtc rims weighing only 5.7kgs each with recent 195/50R15 Toyo R888 tyres (Medium compound)
Vehicle location
Wakefield, West Yorkshire (Note the car is currently SORN)
Price
.£11000
Please Call or email me if interested, you want some pictures or you have any questions
Many thanks,
John
Walters54@hotmail.com
07885971556
AVAILABLE BY SEPARATE NEGOTIATION.
Covered single axle car transporter trailer
Spare set of 13" compomotive cxr wheels with A048 tyres
Shaggydoo
posted on 19/6/16 at 08:06 PM Reply With Quote
Car now sold. SOLD SOLD SOLD
