Author: Subject: Megasquirt MS3X map for Zetec wanted.
Family guy
posted on 19/7/16 at 12:03 PM Reply With Quote
I am trying to get my Zetec 2,0 from 1994 running on MS3X but just dont get it to work. Right now I have no rpm signal for example.
Does anyone have an tune file for a configuration similar to mine? I would much appreciate to have a look and compare to my tune, I´m pretty sure the error is somewhere in the settings.
I am running with all standard parts, except for a wideband oxygen sensor, and an EDIS-4. All connected in accordance with "MS3X hardware manual".
I have not connected the cam sensor though as I am going for batch injection.
//Ronny
ashg
posted on 20/7/16 at 01:40 PM Reply With Quote
sorry i dont have a zetec map as i run a saab engine.
why did you bother getting a ms3x then ruin it by adding an edis4? dump it and run fully sequential ignition and fuel otherwise you have wasted your money and could have just purchased an ms2.
go to www.msextra.com they will be able to help you get it going.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Family guy
posted on 20/7/16 at 02:29 PM Reply With Quote
Well, I didnt really chose MS3X. I got it dirt cheap from a friend, so I should say MS3X chose me.
He ran with EDIS so I thought it should be a walk in the park.
baz-R
posted on 27/7/16 at 07:11 AM Reply With Quote
It's a waste of time trying to use someone else's tune unless you have exactly the same setup.
I can't imagine anyone running edis and ms3x.
Making a tune from scratch is not as hard as you might expect just make sure you start from the generic Base map for your ecu type
