Author: Subject: zetec flywheel to pinto clutch
Monty_CZ
posted on 13/3/17 at 07:43 PM Reply With Quote
I started with pinto to zetec conversion. I have a blacktop zetec 2.0 and type 9 gearbox.
I found that it's good to use 1.8 flywheel (lighter then 2.0) and redrilled it so it will take a pinto clutch (it sould take more power, 215mm dia). So I have bought 1.8 flywheel (part number 928m6398AE) but my pinto coverplate do not line up with dowel pins on that 1.8 flywheel. It's little bit smaller. I thought that pinto cover plate will fit on 1.8 flywheel dowel pins and I will redrill only holes for cover plate mounting bolts. Am I right? If yes what clutch and cover plate should I use then?
johnemms
posted on 13/3/17 at 08:00 PM Reply With Quote
I bought this set up.. Linky
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
madteg
posted on 13/3/17 at 08:19 PM Reply With Quote
You can centralize the pressure plate by measuring for the outside edge of flywheel. Clamp up and drill though fixing holes,
mine ran like this for years till i fitted lightened flywheel.
chris
posted on 13/3/17 at 10:17 PM Reply With Quote
I just fettled dowl holes till it fitted
Monty_CZ
posted on 14/3/17 at 06:31 AM Reply With Quote
how so, that so many people wrote that pinto cover plate fits on dowel pins on 1.8 flywheel? Does anyone has a part numbers of this combination? Maybe I have a wrong cover plate.
chris
posted on 14/3/17 at 06:53 PM Reply With Quote
the locating dowls on the zetec flywheel are just slightly off from the pinto cover plate and a small amount of fettling and it will fit i think the bolt holes are all in the correct place
Monty_CZ
posted on 14/3/17 at 07:34 PM Reply With Quote
in my case they are off quite a lot.
245 mm in diameter between mounting holes on my old pinto cover plate. 260 mm on zetec flywheel.
So the question is, which clutch and cover plate is correct for 1.8 zetec flywheel? Part numbers would be very helpfull.
[Edited on 14/3/17 by Monty_CZ]
Dusty
posted on 14/3/17 at 10:14 PM Reply With Quote
Here's a pic of a lightweight flywheel from Retroford drilled for both zetec and pinto clutch. None of the holes for one quite line up with the other. The benefit of the pinto pressure plate is it's deeper, giving the diaphragm springs a better angle to exert more force so potential torque transmission is higher, like for like. Standard pinto pressure plate and organic clutch plate on mine copes with a modified ST with no problem whereas I got clutch slip with standard 1.8 zetec clutch on a 2.0 blacktop.
[img] Description
[/img]
[Edited on 14/3/17 by Dusty]
johnemms
posted on 15/3/17 at 07:01 AM Reply With Quote
Yep.. 1.8 flywheel new mondeo pressure plate etc.. felt really nice ..But slipped ..
Ended up buying Retroford .. any problems and I could complain. .
