Author: Subject: Repairing Carbon Fibre
JacksAvon
posted on 7/6/17 at 10:08 PM Reply With Quote
Dear collective brain,
I am currently using carbon fibre bodywork on my car.
There are some cracks in the side pods that need repairing, also the nose.
I have no experience of repairing carbon
Any suggestions, ;inks, pointers gratefully received.
Jack
The sickness started in 2001 with a Robin Hood 3A, Prelit Westy,Tiger Cub, Tiger Avon, Tiger R6, 16v Mini, Sylva Fury Fireblade, Westfield Sei, Mallock Mk11, Fireblade Locost, Tiger Avon, Procomp LA Gold, Mk26 Mallock...........and now a Mk18 Mallock.....LR750, Vandiemen FX02
Charlie_Zetec
posted on 8/6/17 at 07:24 AM Reply With Quote
Are you talking surface cracks in the resin, right through the carbon itself, or "I can see sunlight through the damage" ? Pictures might help!
posted on 8/6/17 at 08:31 AM Reply With Quote
Not worked with CF before, but have repaired cracked plastic bumpers. Access to both sides is necessary to glue an internal patch on. However the exterior is then filled, sanded and painted to finish - maybe not what you want though if it's naked CF?
motorcycle_mayhem
posted on 8/6/17 at 08:46 AM Reply With Quote
If it's a simple repair, requiring a simple fix:
Abrade, place carbon over affected/abraded area, work epoxy into the carbon (a flex edge spreader/roller), then stretch a piece of plastic film over the top. Peel off when set.
Repeat on the other side if required.
Anything else, I go back to the mould, wet lay or vacuum bag....
dave36
posted on 8/6/17 at 07:06 PM Reply With Quote
grp repair
Good places to start, look up West systems, loads of info and good place to buy.
also look up http://www.ukmirrorsailing.com/index.php?option=com_content&view=article&id=1284&Itemid=610
free resource, covering finishing as well
[Edited on 8/6/17 by dave36]
Never grew up
JacksAvon
posted on 8/6/17 at 08:31 PM Reply With Quote
Thanks Chaps
Neville Jones
posted on 26/6/17 at 11:33 AM Reply With Quote
Be careful, a lot of carbon mouldings are polyester resin, not epoxy. Although, epoxy shopuld do the job with repairs, but not necessarily so.
Ask the makers what resin they used, then get some matching resin from them or a supplier.
Only talking from many years of experience and balls ups...and believing the internet and forums.
Charlie_Zetec
posted on 26/6/17 at 11:41 AM Reply With Quote
I agree that most resins used are polyester - but even when you key up the surface for preparation, there's no guarantee of adhesion between the "new" and "old" polyester. Epoxy resin will offer a better adhesion to the original polyester.
JacksAvon
posted on 26/6/17 at 01:52 PM Reply With Quote
Thanks chaps
