Author: Subject: Rivets and rust
JohnFol
posted on 11/12/02 at 12:28 PM Reply With Quote
Rivets and rust
ok, you spend ages getting your chassis prep'd and painted to prevent rust. Then you drill 500 holes in it and insert rivets.
What stops the water from going through the rivet into the tubing?
If there is nothing, how do you prevent it rusting internally?
philgregson
posted on 11/12/02 at 12:36 PM Reply With Quote
Option one: Use blind rivets and plenty of sealant.
Option two: Have you considered gluing the panels on? - see 'Bondage' lower down this section.
Phil
JohnFol
posted on 11/12/02 at 01:35 PM Reply With Quote
Saw the 'bondage' bit and have posted quite a few comments. The outcome of that was you still need some rivets somewhere to stop the glued pannels moving around.
Not come across blind rivets. Will do the research, but don't all rivets end up with a hole through the middle?
geoff shep
posted on 11/12/02 at 05:01 PM Reply With Quote
Jon Fol, read about these on a bloke's locost website and searched - found this:
Sealed end rivets
JohnFol
posted on 11/12/02 at 05:06 PM Reply With Quote
I know you're really hiding an inner passion to be a guru on washer and fastener technology .
Seriously, many thanks!
wicket
posted on 11/12/02 at 06:17 PM Reply With Quote
I'm using both dome & c'sk head blind rivets. They are readly available from good fastener suppliers like Namric (the Nut & Bolt Store) in Brighton; RS also stock dome headed ones.
Viper
posted on 12/12/02 at 10:29 PM Reply With Quote
How about don't drive it in the rain
Deckman001
posted on 12/12/02 at 10:46 PM Reply With Quote
I can just imagine the clarke of the cource postponing a race due to 'Rain'
