mad_skillz
posted on 21/12/02 at 09:49 AM |
ford dohc 2.0
does any one know where i can get parts for a dohc 2.0 from a ford G-reg sierra. Ive got the block but there is only the carb and no air filter box
connecting to it etc. Also what is tuning like for these and where can i get parts? Thanks v.much
Alex
jollygreengiant
posted on 21/12/02 at 10:28 AM |
For the air filter box try scrapers/Ford/aftermarket aircleaners.
Tuning wise you could fit efi or talk to burton who allways did know what tweaks worked on what Ford Engines. However I think that you will find that
there is not a lot for that engine.
If you do find anything first make sure that you have a good head (they a known for cracking between the valves on No2 and/or No3 cylinders).
When you refit head from inspection (if sound) Always fit a new timing chain (Genuine Ford, the links are marked for timing) as these are know to be
weak after High milage & should be changed between 80 & 100K.
After that its usual practice of cams and lightening/balancing ( p.s. the flywheel on these is very heavy !)
personally I would be more tempted to dig a 2.0 Zetec out of a Mondeo (More bits available & you get 16V instead of 8V)
mad_skillz
posted on 21/12/02 at 02:20 PM |
thanks v.much,
i will upgrade eventually just when i get the cash! i think i will go for the 2.0 ztech.
Alex
p.s is this what is used in the rs200, i though i saw it on top gear @1000bhp?
david walker
posted on 21/12/02 at 05:01 PM |
The RS200 ran with a Cosworth 1800 BDT in std form. This bears abbsolutely no resemblance to a DOHC whatsoever (although it can trace its origins back
to a X Flow - just).
Did you mean RS2000 (Mk5)? That used a 16v variation of the DOHC motor and gave 150 bhp in std form. Was a pretty good motor and went out to 2.3 in
the Scorpio.
By the way, concerning using an EFi system on a carb DOHC, you will have some problems to overcome as the heads are different.
About 10 yrs ago "CCC" mag tried to tune a DOHC motor and really struggled to get much out of it even with modified cams. I seem to recall that they
got it up to about 140 bhp but it took quite a bit of effort.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
mad_skillz
posted on 21/12/02 at 06:25 PM |
not the dohc, i meant there was a rs200 kit car on top gear i think and it had a zetec. What kind of power can i get outa one of them?
david walker
posted on 21/12/02 at 07:13 PM |
I didn't see the RS200 replica on Top Gear. If it didn't use the BDT engine then it could have been the Cosworth YB Sierra/Escort unit as this is
often used in these cars - same unit as Hicost uses.
The 2.0 Zetec is reasonably tuneable, not as good as the YB or 16v Vauxhall but in moderate state of tune - cams and forty fives is OK for about 180
bhp. Remember that most horsepower claims that you read here and elswhere are exagerated!
johnston
posted on 21/12/02 at 07:36 PM |
for the 2.0 dohc phone ht racing theres been a few cars with engines theyve built in classic ford
ijohnston99
posted on 22/12/02 at 09:04 PM |
The RS200 on top gear was genuine I believe and JC trashed it!!! ![](/images//smilies/shocked.gif)
