Author: Subject: Made a rain cover and now the sun shines!
zetec
posted on 1/8/07 at 01:03 AM Reply With Quote
After getting pissed off watching the rain clouds blowing across the weather forecast every time I wanted to go any where I decided to have a bash at making a cover. Then if it gets a bit too damp I can retire to a cafe/pub and carry on in a dry car when it stops.
With age I'm getting a bit mean with the old £££ so bought some nylon off Ebay, a few fasteners and got to work with paper patterns, Mrs. Z's sewing machine and a few spare hours.
More than a few hours later....the results. I must say half way thru the £250 Softbits charge looks mighty good value!
And now the summer is here I bet I don't need it.` Rescued attachment DSCF0142.JPG
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
RazMan
posted on 1/8/07 at 06:06 AM Reply With Quote
Start up a business then! At least we will get to drive our cars this summer
The fit looks really professional - well done
[Edited on 1-8-07 by RazMan]
Raz
Danozeman
posted on 1/8/07 at 06:14 AM Reply With Quote
Looks good that mate. U should make a few.
Dan
Davey D
posted on 1/8/07 at 07:20 AM Reply With Quote
looks great! now that you know how to make them you should churn a load of them out
dr-fastlane
posted on 1/8/07 at 07:23 AM Reply With Quote
Well done. I do a rain dance for you
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
donut
posted on 1/8/07 at 08:39 AM Reply With Quote
Up to your usual high standard i see!! So how much did it cost you to make?
posted on 1/8/07 at 11:57 AM Reply With Quote
£249 ?
Seriously though, it does look excellent and a very good fit. Was it difficult to fit the press studs to the bodywork?
zetec
posted on 1/8/07 at 06:14 PM Reply With Quote
press studs are easy to fit if you have the former for fitting the femaile to the cover, got mine in the local sewing shop £3.00 and comes with a few sets of studs.
Whole lot come to about £20 with the lift dot fasteners adding most to the cost. Suspect with just press studs used and cheap material off Ebay could be £10...and a few hours mucking about. Knack seems to be to get the front made and fitting OK then move back, cutting and fitting studs until you get to the rear. Then make up the seat and steering wheel covers.
No seam tape fitted yet, I have seen some repair tape on ebay which looks just right...that said I did a trial run and no leaks so far. I did stitch strips of vinyl into each seam to add strength so poss that is helping to seal it.
Make your own, it's character building ...Much like being forced to watch Big Brother.
[Edited on 2/8/07 by zetec]
