Author: Subject: Aeroscreen fittings
Paul TigerB6
posted on 27/3/08 at 12:28 PM Reply With Quote
Aeroscreen fittings
Can anyone with a fibreglass aeroscreen tell me what they found the neatest fittings are to fit it to the scuttle?? I was looking for some black allen fitting button heads but am struggling to find some on ebay at the moment
Could go for these but seem a little over the top
linky
[Edited on 27/3/08 by Paul TigerB6]
Mr Whippy
posted on 27/3/08 at 12:39 PM Reply With Quote
how about the plastic clips used for fitting motor bike windsceens?
There usually used in production cars to hold the inner plastic wings on so you could just get them out the scrappy. Very strong as the scars on my hand testify
http://www.replicastuk.com/prod5.asp?prod_id=8179&id=212&grpid=8179&msg=&offset=#prod_anchor
[Edited on 27/3/08 by Mr Whippy] Rescued attachment ScreenRivets.jpg
nitram38
posted on 27/3/08 at 12:57 PM Reply With Quote
What about black number plate nuts and screws?
Being plastic, they won't rust!
iank
posted on 27/3/08 at 01:03 PM Reply With Quote
Plain button heads + can of old engine oil + blowtorch + thick gloves, goggles and pliers => black button heads.
Heat em up drop em in. Do outside
http://www.locostbuilders.co.uk/viewthread.php?tid=76424
Anonymous
Humbug
posted on 27/3/08 at 01:17 PM Reply With Quote
Similar to the ebay ones, but including plastic washers and rubbery nut thingies, desogned for m/cycle screens, are about a tenner for a packet of 8 from Halfords. That's what I used, and I'm pleased with the result
westcost1
posted on 27/3/08 at 04:27 PM Reply With Quote
i have fiber glassed some bolts to the inside of the aero screen then drilled holes through the scuttle and bolted it down easy and no nasty fixings showing at all
westcost1
posted on 27/3/08 at 04:50 PM Reply With Quote
Paul TigerB6
posted on 27/3/08 at 05:29 PM Reply With Quote
Now there's a brilliant idea. Looks really neat too. How did you manage to mark out where you needed to drill holes accurately??
Paul
nitram38
posted on 27/3/08 at 08:51 PM Reply With Quote
I would have thought, drill the holes in the scuttle and poke a marker through to the aeroscreen, and then glue the bolts to the aeroscreen on the marks?
That's the way I would have done it !
[Edited on 27/3/2008 by nitram38]
Paul TigerB6
posted on 27/3/08 at 08:54 PM Reply With Quote
Good idea mate - makes sense when you put it like that doesnt it. Scuttle is still off so think i might just do that before fixing it down.
Paul
