Author: Subject: fuel filler in the boot
smart51
posted on 11/7/08 at 08:29 PM Reply With Quote
My 3 wheel build uses the donor's fuel tank which has a filler cap straight on the top. I've put it under the boot which means the filler is in a recess in the boot floor. It is easy enough to reach through the rear window without having to lean in. The filler itself is SVA OK. Is the SVA tester likely to object to its location?
edit to say it is the filler cap further in to the boot. The nearer one is the coolant reservoir.
James
posted on 11/7/08 at 08:36 PM Reply With Quote
Either the boot or the filler cap has to have a lockable lid.
HTH,
James
smart51
posted on 11/7/08 at 08:39 PM Reply With Quote
The boot will be lockable.
James
posted on 11/7/08 at 08:42 PM Reply With Quote
Well, unless the SVA rules on this have changed in the last 3 or so years it's fine.
Unless, of course, the SVA rules for 3-wheelers are different?
James
posted on 11/7/08 at 08:57 PM Reply With Quote
HTH,
James
You sure?
If so don't tell the SVA inspector for my two tests Non-lockable boot cover, non-lockable lid.....
indykid
posted on 11/7/08 at 10:27 PM Reply With Quote
it doesn't have to be lockable, it has to be secure.
both words can mean the same thing, but secure also means it holds fuel in and doesn't rattle itself open as you're driving down the road. that's what's required.
tom
James
posted on 14/7/08 at 02:14 PM Reply With Quote
Sorry!
My mistake!
Been 2 years now since my SVA and beginning to forget the details!
James
