<<  1    2    3    4    5  >>
Author: Subject: Gulf MNR Vortx
Digimon
posted on 28/5/13 at 02:48 PM Reply With Quote
Sounds good to me mate, where have to sort something out soon
Digimon
posted on 30/5/13 at 10:15 AM Reply With Quote
I've ordered some goodies for the car this week, I can't get the SPA water temp gauge to properly it's just too complicated and after spending 2hours at the weekend with the manual I’m still no closer to getting it working, so I’m going to replace it with a nice simple gauge
I have also ordered a Quick Shifter, after being in Hopsky’s car a few weeks back this is a great bit of kit for the money
big_l
posted on 31/5/13 at 07:13 AM Reply With Quote
Pleased your having fun looks in good nick still..
Get your arse up to Newark show organise a convoy it'll be a good show there's a live band on again this year on the Satarday night !!
Check out my blog mnrvortxhayabusa@blogspot.com
johnny chimpo
posted on 31/5/13 at 03:22 PM Reply With Quote
Very interested in the quick shifter. Can you give me any more details on it or is there a website for them?
daniel mason
posted on 31/5/13 at 03:46 PM Reply With Quote
what happened to the kliktronic push button gearshift i had? that was a great setup!
Digimon
posted on 31/5/13 at 06:07 PM Reply With Quote
I will try my best to make this show but ill properly come up in the Mondeo
Its from Race Gadgets on eBay, it has gone up £10 today tho
QUICKSHIFTER - Rapid-Shift from RaceGadgets with universal position sensor. | eBay
I'm not sure Daniel, the buttons have been taken out of the steering wheel. it may of been fitted to David's new car?
hopsky1
posted on 2/6/13 at 07:17 PM Reply With Quote
very easy to install makes upshifting smoother and made my lap times quicker
Digimon
posted on 2/6/13 at 07:42 PM Reply With Quote
We I've not had a very good weekend with the car, I got the quick shifter fitted and then went got a quick test drive and the bottom end has gone its now making a horrendous knocking noise
We have spent today getting the engine out and hopefully take it apart this week to see if we can find whats damage
Ben_Copeland
posted on 2/6/13 at 08:06 PM Reply With Quote
Oh bugger
Give me a shout if your stuck for any tools or need a hand mate. I've rebuilt a few engines.
Ben
Locost Map on Google Maps
Enter Your Details Here
big_l
posted on 3/6/13 at 08:16 AM Reply With Quote
Ahh not ideal !
Digimon
posted on 4/6/13 at 04:06 PM Reply With Quote
Originally posted by Ben_Copeland
Oh bugger
Cheers Ben, I will do if I get stuck on anything
Digimon
posted on 4/6/13 at 04:08 PM Reply With Quote
Am I stuck with the early 4XV R1 engine or can I fit a later fuel injected engine?
Are the engine mounts the same on the later engine's?
Anyone know?
Simon
gaz_gaz
posted on 4/6/13 at 04:28 PM Reply With Quote
Not easy to swap them over,
The 5pw is taller, and the mounting points are diff in the head, will need the cradle and mounts modifying to suit,
You will also need an alternative fuel pump and another fuel line added.
I've been looking at this myself lately but stuck with carbed R1 power.
I have a spare 4xv as well as 2 complete engines worth of spares if you need anything
5jj is a drop straight in choice as well,
[Edited on 4/6/13 by gaz_gaz]
sdh2903
posted on 4/6/13 at 04:37 PM Reply With Quote
Something i've looked at too, you need new cradle, power commander, speedo healer if you dont have one, shed load more wiring etc. A definite job for winter. The 5jj is a straight swap and has a stronger gearbox so would be the one to look out for.
There are usually half a dozen cheap 4xv short motors on ebay I would get one to see me through the summer and then look at rebuilding/upgrading come winter time. Short motor swap and you would be back on the road in no time.
TimC
posted on 4/6/13 at 04:48 PM Reply With Quote
That should be a 5JJ engine in there - that's what I fitted. Many of the part numbers still start 4XV but it was a 5JJ when I built it. I have no idea what the engine number was to check it.
Check the ECU number.
[Edited on 4/6/13 by TimC]
hopsky1
posted on 4/6/13 at 05:51 PM Reply With Quote
Anyone know?
Simon
you cant go injected youve already got more power then me
hopsky1
Anyone know?
Simon
Digimon
posted on 4/6/13 at 07:02 PM Reply With Quote
Thanks for your reply's guys, looks like i'm going to stick to the 5JJ engine then just got to find one now
Tim, your right its got a 5JJ engine still
gaz_gaz
posted on 4/6/13 at 07:09 PM Reply With Quote
Ring MNR, they have a low miles 5jj they bought from a forum member.
I personally had an engine rebuilt by Jon JEBS performance who was recommended by Malc at Yorkshire engines,
Not much more than a replacement second hand engine and he turned it around in a couple of weeks.
TimC
posted on 6/6/13 at 01:36 PM Reply With Quote
I have just stumbled across an image of the original receipt for the motor!
Receipt
Receipt
Digimon
posted on 6/6/13 at 01:48 PM Reply With Quote
That's brilliant thanks Tim, ill have a look at the weekend and see if its the same engine.
I guess its done well if its still got the original engine fitted, how long do they genuinely last once fitted in a car ( Just out of interest )
Simon
Digimon
posted on 10/6/13 at 08:06 PM Reply With Quote
I've been busy this weekend, picked up a replacement 5JJ engine from a nice chap in High Wycombe. It's pretty much built up and cleaned ready to be fitted back in the car, just waiting for 2 sump gaskets so I can fit the baffle plate
TimC - I had a look at the old engine and it is the same one you fitted so its not done bad
Digimon
posted on 10/6/13 at 08:21 PM Reply With Quote
Hopefully someone will be able to answer this one, the original plug has been cut off the generator ( Alternator ) and all the wires are white
Does it matter which order they are plugged back in or can they go anywhere?
The replacement engine still has the original plug and i'm not sure which wire is which now
[Edited on 10/6/13 by Digimon]
yorkshire-engines
posted on 10/6/13 at 08:39 PM Reply With Quote
Hi the genny wires are all same so it don't matter which you connect them to
cheers Malc
Digimon
posted on 10/6/13 at 08:43 PM Reply With Quote
That's brilliant thanks for your help
<<  1    2    3    4    5  >>
