<<  4    5    6    7    8  >>
Author: Subject: Gulf MNR Vortx
TimC
posted on 28/5/15 at 11:25 AM Reply With Quote
Originally posted by Digimon
I like the wooden grip
It's a bit of fun really - I took inspiration from the balsa knobs on the Porsche 917.
Great to see that my old MNR is charging-well.
Digimon
posted on 1/6/15 at 03:02 PM Reply With Quote
Thanks Tim, hopefully the car should keep getting better and better. I've still got a big list of things I want to improve on the car
Digimon
posted on 14/6/15 at 12:43 PM Reply With Quote
Gave the MNR a good spanking yesterday, it didn't miss a beat all day
Digimon
posted on 28/11/15 at 06:04 PM Reply With Quote
My winter upgrades have started for this year. I've been wanting to freshen up the front since I got the car and since it needs a new front wheel bearing anyway this is a good excuse to make a start.
I've picked up the following bits over the past few weeks
2 x M16 caliper seal kit
M16 caliper stainless steel locking tabs
2 x Quinton Hazell wheel bearing kit
M16 Ferodo ds2500 pads
Some sandblasting later and some Plasti-Kote stove paint recomended from the TurboSport forum
Digimon
posted on 28/11/15 at 06:06 PM Reply With Quote
I've not been looking forward to the next bit but I have got some carbon CSR wings to fit
I'm going to try and make my own stays over the next few weeks
CosKev3
posted on 28/11/15 at 08:46 PM Reply With Quote
Nice job on the hubs and calipers, look spot on.
Digimon
posted on 28/11/15 at 10:32 PM Reply With Quote
Thanks Kev
Digimon
posted on 27/2/16 at 05:47 PM Reply With Quote
I've not been able to work on the MNR much lately because I have been working on my dads mk1 Escort. It's gone through quite a transformation over the last 18months. if anyone whats to have a look here's the link
http://www.turbosport.co.uk/showthread.php?t=627342
Wrapped my exhaust today with PitKing Products Volcano Exhaust Wrap from JJC Rally
Can't believe I needed 100ft of the stuff but it does look good
Digimon
posted on 29/2/16 at 09:20 AM Reply With Quote
Made a good start on getting the other side finished off on Sunday, almost finished rebuilding the other caliper
One more of the wrap for good measure
Digimon
posted on 26/4/16 at 08:19 PM Reply With Quote
Oil Cooler time, I have been working on this for sometime now and its finally all finished
The parts I've used for others wanting to fit an oil cooler to the 4XV/5JJ engine are...
C43 Oil to Water Laminova cooler, I've got a Medium (180mm long) is equivalent to a 16 row
Torques Universal Oil Sandwich Plate with AN-08 fittings and Take Off Cover with M20x1.5
2 x Straight AN-8 oil fittings
2 x 90 Degree AN-08 fittings
1 Meter of AN-08 oil hose
M20x1.5 joining bolt, I used the oil fitter adapter from my old R1 engine
Because of the oil filter bolt I needed to machine the back of sandwich plate to allow more room for the bolt to sit, I also needed to shorten the cover because it bottomed out on the joining bolt
I have also drilled and tapped a 1/8NPT hole into the cover to keep my oil pressure feed in the same place, I know the oil temp sender isn't in the best place but it will give me a good idea of what the oil temp is doing
bi22le
posted on 26/4/16 at 08:58 PM Reply With Quote
Any reason you went for an oil to water cooler and not an oil to air cooler (std row rad)?
I have just rewatched the Llydden Hill vid you posted up from last year (I think). That white and black scooby needed to move the fudge over!!
Please read my ring story:
Digimon
posted on 26/4/16 at 09:15 PM Reply With Quote
I like the added benefit of the water preheating the oil and when looking at my car it was going to fit really neatly in the engine bay
Digimon
posted on 26/4/16 at 09:19 PM Reply With Quote
I know he was getting annoying, even after slowing down I managed to catch up with him again lol
Digimon
posted on 8/5/16 at 07:15 PM Reply With Quote
I have replaced the breather tank today because what ever I try I can't stop the old one from leaking.
I've also relocated it so the hoses are a lot shorter, I think it looks a lot better in the front. I used 28mm exhaust clamps to save drilling into the chassis
Digimon
posted on 26/5/16 at 12:24 PM Reply With Quote
Another successful day at lydden, my oil temps are really good and the oil pressure is about 5psi higher at idle when hot
[Edited on 26/5/16 by Digimon]
miskit
posted on 26/5/16 at 09:28 PM Reply With Quote
Great Video! Esp the sound without vibrations or wind noise.
I could see you getting faster and smoother every lap a really good watch.
Digimon
posted on 27/5/16 at 08:22 AM Reply With Quote
Thanks miskit, I fell like im making progress in the car. I have been following Driver 61 Uni videos and learning a lot from them.
www.driver61.com
I have modified my camera to take an external microphone. I'm really happy with the result the sound it so much better now, I want to try a diffuser to see if I can make the sound a little deeper
This is the camera
Turnigy HD ActionCam
I used some network cable and a 3.5mm socket from ebay
Digimon
posted on 25/7/16 at 08:38 AM Reply With Quote
Not much of an update but I have made up a little rear diffuser from 1.5mm aluminium
Digimon
posted on 11/8/16 at 07:47 AM Reply With Quote
Trying to get my car past the noise tests at brands hatch and other tracks I've made my standard MNR exhaust repackable. It might not work and it doesn't look the best but it's worth a try, if it doesn't work I'll have to look at a much bigger exhaust.
I had an old stainless steel exhaust I used for parts, I have extended the perforated tube and banded the end cap with captive nuts.
I have got Acousta-fil packing and some exhaust paste to finish it tonight
Ben_Copeland
posted on 11/8/16 at 08:53 AM Reply With Quote
Good effort !
Where you not trying to sell it last month
Ben
Locost Map on Google Maps
Enter Your Details Here
Digimon
posted on 11/8/16 at 09:17 AM Reply With Quote
Thanks mate
Yeah I was thinking about it but i'm not sure if its the right thing to do, its been such a good car
Digimon
posted on 12/8/16 at 12:33 PM Reply With Quote
Continuing on with the exhaust, the manifold has been blowing since I fitted the exhaust wrap but the last time I used the car it was really bad.
Ordered up some new copper gaskets and changed them over last night, no wonder it was blowing I've lost half gasket on cyl 3
Digimon
posted on 19/3/17 at 05:57 PM Reply With Quote
I've finally finished my front recovery eye this weekend. I've made it removable so I can fit just for trackdays, its turned out quite good I can lift the car up without the bar flexing and touching nose cone
CosKev3
posted on 19/3/17 at 07:51 PM Reply With Quote
Looks good,but aren't you concerned about the damage it could cause if you have a off on track?
Without it fitted a small off could be a new nose cone and rad,with it fitted if the exhaust clamps hold you will sustain chassis damage,if the clamps break it would probably spear the engine?
Digimon
posted on 19/3/17 at 08:28 PM Reply With Quote
That is a concern, I have been thinking about recessing the hoop back more.
This was the best solution I could come up with, if I do need recovering I didn't want anything pulling on the front suspension. I've heard Brands Hatch require a front towing eye before going out on track
<<  4    5    6    7    8  >>
