Author: Subject: IVA Steering Wheel
andrew_s
posted on 21/9/15 at 01:23 PM Reply With Quote
IVA Steering Wheel
I currently have an OMP steering wheel on a quick release boss
I made a crash pad, but it doesn't look very good
Any recommendation for a steering wheel and crash pad that will fit the qr boss. I have blocked the QR boss from working.
Any advise greatly appreciated - test is next week, and the nerves are setting in....
Slimy38
posted on 21/9/15 at 01:49 PM Reply With Quote
I can't directly help, but I should mention that IVA isn't looking for 'looks good'... If it's secure and would do the job then you should be fine. So what if it accidentally falls off after IVA?
theduck
posted on 21/9/15 at 02:44 PM Reply With Quote
This passed as it is
andrew_s
posted on 21/9/15 at 02:47 PM Reply With Quote
will take a pic tonight - when did that pass ?
I have the horn push but that's it (I could cover the horn icon as its not the horn)
907
posted on 21/9/15 at 04:43 PM Reply With Quote
I have a Momo Race, and Dennis at Norwich was only concerned that it would collapse if I were to hit it.
It's fitted to a Vauxhall Nova column and once he had groped the expanded metal bit within the scuttle he was happy.
Paul G
Will it pass IVA ?
Will it pass IVA ?
[Edited on 21/9/15 by 907]
theduck
posted on 21/9/15 at 04:45 PM Reply With Quote
May at Kidderminster.
micksalt
posted on 22/9/15 at 07:54 AM Reply With Quote
I purchased one of the Racetech steering wheel padding (Suede) for 265 - 270mm steering wheel for my steering wheel but it was the wrong shape. I'll happily drop it in the post for you and you can give it a go.
andrew_s
posted on 24/9/15 at 06:50 PM Reply With Quote
U2U sent thank you
andrew_s
posted on 26/9/15 at 11:45 AM Reply With Quote
huge thanks to mick for the crash pad, not sure its big enough however, so:-
I have the crash pad
the pad I made (which is not that good looking)
or I could go with an option like micks of using neoprene
or the horn push
here's a link to some photos
link
what do people think? I just don't know what to do for the best on this point
the small pad will cover the screws that will disable the quick release so that something, and I can double sided sticky tape it on
the pad I made (the bigger one) has the screws to disable the quick release in it
thanks in advance
