New Topic New Reply
Author: Subject: Transmission Tunnel Aluminum
RoadsterDave62
posted on 24/3/16 at 07:33 AM Reply With Quote
Hi Guys
Waiting for my Haynes Roadster body to be delivered so thought I would panel the interior.
My question is should I use 0.9 mm or 1.2 mm aluminium, I would prefer 0.9mm but what to be sure it will be suitable.
Thanks in advance.
Dave
gary gsx
posted on 24/3/16 at 09:27 AM Reply With Quote
Hi mate
Think most people use 1.2 that's what I'll be using when I get there ☺
What body work supplier you using?
Garf
macc man
posted on 24/3/16 at 03:50 PM Reply With Quote
Bear in mind if your propshaft lets go a thicker metal would be safer. Or fit a prop catcher.
[Edited on 24/3/16 by macc man]
scutter
posted on 24/3/16 at 04:54 PM Reply With Quote
Prop catchers would best of your worried about it letting go, 0.3mm of alloy isn't gonna make much differance to 2kgs of spinning steel.
TAB Dan.
loggyboy
posted on 24/3/16 at 05:00 PM Reply With Quote
I'd only be worried about it flexing and kinking with 0.9 when its kicked or lent on.
Mistral Motorsport
Bluemoon
posted on 24/3/16 at 07:30 PM Reply With Quote
TAB Dan.
Ditto if the prop gets out of light sufficiently to hit the alloy panels, even 1.2mm would not be enough, it bashes the living daylights out of the chassis tubes... locostbuilders search will provide "interesting"/"enlightening" viewing...
Dan
Mark100
posted on 24/3/16 at 10:28 PM Reply With Quote
Im putting on prop catcher and 1.0mm ally composite its plastic on both sides available in loads of colours form a lad on here
realy light stuff it is too
New Topic New Reply
