the_big_1
posted on 23/9/17 at 07:13 PM |
HELP!!! Transmission
HELP!!!
I took the top inspection plate off my type 9 gearbox and now the selector shaft wont move, can not get the plate back on etc.
I was following the Haynes gearbox manual and only got to take off cover and select reverce and that was it, shaft wont move!!!!
Anyone in the midlands can help before I have to scrap the box and buy another?
mackei23b
posted on 23/9/17 at 07:33 PM |
you need to have the selector in the right position to get the plate back on....or it will jam...
gremlin1234
posted on 23/9/17 at 07:46 PM |
and while it is off it is quite possible
that more than one gear is selected
ianhurley20
posted on 23/9/17 at 09:00 PM |
Thought you said you were an engineer?
the_big_1
posted on 24/9/17 at 11:56 AM |
Will have to find someone in the midlands that can rebuild the box. One of the spring rings isn’t located either so I guess to needs a full strip down
now :0(
posted on 24/9/17 at 05:35 PM |
If the box is a standard type 9 then it's well worth getting it rebuilt so it has a high first gear as the standard ratio isn't very good
for a seven type car. One of the best mods I have done to my cay , recommend BGH Gearteck.
the_big_1
posted on 25/9/17 at 11:44 AM |
Hi All,
Anyone any idea what the 5th gear nut size is? A lot of forums say 30mm but its bigger than the 30mm socket I have.
Cheers!!!
