Author: Subject: Lower seatbel fixings points: photos?
JoaoCaldeira
posted on 10/7/06 at 07:06 AM Reply With Quote
Hi all.
Have you VortX builders photos of how you fixed the seatbelt (lower fixing)?
Thanks in advance,
Joao
posted on 10/7/06 at 08:02 AM Reply With Quote
These are photos of the MK Indy lower and upper fixing points if that helps Rescued attachment dscf00014.jpg
posted on 10/7/06 at 08:03 AM Reply With Quote
posted on 10/7/06 at 08:04 AM Reply With Quote
sorry should have read your post properly before posting
JoaoCaldeira
posted on 10/7/06 at 09:17 AM Reply With Quote
Hi mate.
Thanks anyway
Any VortXers?
Joao
RichieC
posted on 10/7/06 at 10:02 AM Reply With Quote
Here you go Joao. Just consist of the eyebolts fitted through the corner plates in the floor and then fitted with a load spreading washer and 7/16 UNF nyloc.
Rgds
Richie
JoaoCaldeira
posted on 10/7/06 at 10:18 AM Reply With Quote
Thanks Richie.
Is there any specification on the eyebolt?
Any would do?
Thanks again for the pic,
Joao
PS: Is your fuelling fully sorted?
amalyos
posted on 10/7/06 at 10:20 AM Reply With Quote
They have to be 8.8 marked. you can buy them on Ebay.
Steve.
RichieC
posted on 10/7/06 at 10:25 AM Reply With Quote
Hi Joao, yep agree with what Steve says they need to be 8.8 grade however some argue the SVA manual states they can be unmarked.
You can get them from MNR too.
Fuelling is 100% better and I located the misfire. I re terminated the HT leads and it has gone. Carb wise, Ive blocked the air jet next to the pilot air jet and the thing is off - massive difference. It like most carbed BECs will benefit from a jet kit but for now its fine and more importantly - safe.
Rgds
Rich
[Edited on 10/7/06 by RichieC]
marc n
posted on 10/7/06 at 10:51 AM Reply With Quote
a pic of bolt in harnesses below for you Rescued attachment seat-belt-pic-for-joao.jpg
please email rather than u2u
chrismnrltd@btinternet.com
