Author: Subject: Side repeater...
posted on 16/2/08 at 01:45 PM Reply With Quote
Side repeater...
Any objections to me putting my side repeaters down on the main body work instead of the scuttle on my MNR?
I see MK's and the like with them down there but almost all the MNR's have them on the scuttle. Why is that??
stuart_g
posted on 16/2/08 at 02:03 PM Reply With Quote
I don't know if there is any SVA requirement/rule on where they should go, but personally I would not want to cut my side panel to fit them there.
Guinness
posted on 16/2/08 at 02:11 PM Reply With Quote
If I was doing mine again, I'd fit the side repeaters in the main side panel. Makes removing the scuttle easier for access to the wiring, IMHO.
I guess it's just a matter of where they look good / comply with SVA requirements.
Steve, just in case you haven't got a copy handy, this is the image from the guide (I think!)
Light Angles
Light Angles
Mike
Guinness
posted on 16/2/08 at 02:13 PM Reply With Quote
[img][/img]
posted on 16/2/08 at 02:22 PM Reply With Quote
Thanks Mike, I was thinking along the same lines as you, easy to remove the scuttle and down on the sides permanent hard wiring.
martin1973
posted on 16/2/08 at 06:40 PM Reply With Quote
my westy has them in main body
martin
RickRick
posted on 16/2/08 at 09:24 PM Reply With Quote
what about getting some of the stick on ones and mount them on a bracket between the scuttle and main panel
