Author: Subject: gear peg
jambo
posted on 17/6/08 at 08:38 PM Reply With Quote
gear peg
got this from mnr.
how does this turn into a gear cable pull.
also the clutch cable ends at the clevis and the outer cable mount dont fit the engine locations,do you drill out the engines bits or is it the wrong cable. Rescued attachment gear peg.jpg
worX
posted on 17/6/08 at 08:43 PM Reply With Quote
Not sure about the "engine locations" you mention, but with regard to the gear spigot thing in your hand, then you simply weld a piece of flat bar off the splined clamp at the back (careful not to weld so much as it can't be clamped shut) and then drill holes into the flat bar to take the adaptor for your cable.
jambo
posted on 17/6/08 at 09:13 PM Reply With Quote
by engine locations i mean,the clevis that retains the end on the clutch cable and the locator on the engine that holds the outer clutch cable stop.
marc n
posted on 17/6/08 at 09:21 PM Reply With Quote
yep gear spline needs a suitable lug welding on ( length depends on your setup / position of pivots on lever / paddles
on a zx10 you will need to drill out to suit clutch cable
cheers
marc
please email rather than u2u
chrismnrltd@btinternet.com
