Author: Subject: cycle wings.....help
germanguy
posted on 13/6/10 at 03:46 PM Reply With Quote
been giving my car a god run today and found that one off my front carbon wings decided to part company with the metal strut what is the best adhesive for it ??
austin man
posted on 13/6/10 at 03:48 PM Reply With Quote
silkaflexmake sure you clean the area and rough it up slightly to get the best adhesion
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 13/6/10 at 03:51 PM Reply With Quote
i drilled some holes in my bracket to allow extra adhesion
omega0684
posted on 13/6/10 at 03:53 PM Reply With Quote
bolt them on
nitram38
posted on 13/6/10 at 08:44 PM Reply With Quote
I did two things on mine.
1) I drilled the side wall of the wing and sent the bar through, not under the lip.
2) Once the bar is glued and set inside the wing, I used aluminium mesh to glue over the bar and increase the area contact with the wing. I smeared glue all over and through the mesh.
1 year and no sign of them coming off.
nitram38
nitram38
posted on 13/6/10 at 08:46 PM Reply With Quote
nitram38
posted on 13/6/10 at 08:50 PM Reply With Quote
germanguy
posted on 15/6/10 at 07:04 PM Reply With Quote
ok done now thanks
