Neil P
posted on 11/1/09 at 08:48 PM |
Cutting wheelarches.
I have a pair of rear arches that are a bit too wide.
I want to narrow them down a bit and wondered if anyone has advice on how to do it.
I need to cut them down by about 45mm which I'm going to take from the inside. This will cut off the moulded flange and the question really is
should I take a strip out and try to bond the flange back on using glassfibre for a larger surface to bolt or rivet or just cut off the flange and
bond the arch directly to the body with PU adhesive. Will that have sufficient strength?
I've heard all sorts of wonderful things about PU adhesives but as a first time builder I have no experience of what it is really capable of.
Neil
posted on 11/1/09 at 09:22 PM |
Personally, Id cut the flange off and bond another flange back on using a fibreglass kit.
Phil
posted on 11/1/09 at 09:23 PM |
^^^ that sounds like a lot of t***ting about - what about getting correct width arches and selling the ones you have?
I can understand needing to do this if you car was in some way unique but wheelarches come in different sizes and colours.
[Edited on 11/1/09 by 02GF74]
londonsean69
posted on 11/1/09 at 10:04 PM |
If you're happy with doing that sort of work (cut and shut) then just get a pair of ebay the right size, then tart them up.
I see em on there, swith a few scratches etc. for about £25 from time to time. They would just need sanding and paintin, maybe a touch of filler
If yours are good nick, you should flog em easy to make back the money, and pay for a bit of paint as well
Failing that, you are going to have to cut them, then joint them with fibreglass on the inside, then fill the visible side, then sand, prime and
paint.
omega 24 v6
posted on 11/1/09 at 10:19 PM |
Did mine's this way. Easy job and very minimal filling to the exterior of the wing after reglassing the flange back on.
Neil P
posted on 11/1/09 at 11:47 PM |
Thanks guys,
I do like the shape of the ones I have, I'll have a go at cutting and glassing them, then.
Neil
RK
posted on 12/1/09 at 02:07 AM |
Grinder to cut down the middle. Don't forget you'll lose a bit just by doing that. Search here on "widening arches".
It's the same in reverse. I have actually done this successfully with a scuttle.
Neil P
posted on 12/1/09 at 09:32 AM |
I considered that and it looks like a good option usually because it leaves both edges unaffected. Unfortunately my arches have a sloped rather than
flat top and each side would have different radius if you took a section out of the middle.
I think I'm going to try cutting the arch to the right width, mark round the inside radius onto the original flange and cut it so that it fits
within the arch then fix it back into place. That should save me having to refinish the outer surface, the actual join will be at the rear of the arch
where it sits against the body.
I don't suppose the location of the joint really makes much difference.
Neil
Triton
posted on 12/1/09 at 10:10 AM |
It's doddle...cut them down to the size you want then sit the arch on a flat board and lay up inside the arch to get the flange back..thing is
cutting them down might alter the diameter of the wing as they usually taper.
www.tritonraceseats.com
www.hairyhedgehog.com
posted on 12/1/09 at 11:18 AM |
quote: Originally posted by Neil P
Thanks guys,
ok then if you insist..... search forum for how the Whipmeister did it, albeit for front cycle wings but the process would be the same.
posted on 12/1/09 at 12:21 PM |
If the edge is bit untidy, you can always use some tadpole trim to hide it.
Phil
alexbishop123
posted on 13/1/09 at 11:03 AM |
damn that a big cat!
