Author: Subject: R1 Fault code
MK chippy
posted on 1/3/09 at 10:47 PM Reply With Quote
R1 Fault code
Hi guys,
Sorry more R1 probs! Everytime i turn on the ignition error code 14 comes up on the dash! I have a rough idea on what it is but no idea on how to get rid of it?! Any help on exactly what the problem is and how to sort it?
Its an 06 R1
Dave
adithorp
posted on 1/3/09 at 11:00 PM Reply With Quote
13+14=Intake air presure sensor
http://jpsc.org.uk/forum/
Steve Hignett
posted on 1/3/09 at 11:08 PM Reply With Quote
As above, I think 14 is from the sensor that was in the ram air pipes...
MK chippy
posted on 1/3/09 at 11:12 PM Reply With Quote
cheers guys
its as i thought. But the annoying thing i that greg (corrado vr6 on here) is also building an indy with the same model R1. as far as i can tell we have the same setup and he doesn't have the fault code. Any ideas on how i can get rid of the code? Tests, checks etc?
Dave
spdpug98
posted on 2/3/09 at 08:53 AM Reply With Quote
Dave
Have you tried swapping Greg's air intake pressure sensor with yours, maybe that yours could be faulty
Dave
My Blog: http://spdpug98.wordpress.com/
road warrior
posted on 2/3/09 at 02:21 PM Reply With Quote
Have you run the engine yet? It won't clear until the engine is idling. Otherwise you may need to clear the code through the dash DIAG 62. There are some links to the workshop manuals available for download in this thread HERE
You will also be able to check the sensor live through the dash in diagnostic mode.
