Author: Subject: Freelander diff... what oil to put in?
Red16
posted on 29/6/10 at 11:23 PM Reply With Quote
I'm after some advice regarding my Mac Worx ZX10r... I've tried searching but it's not returning any results.
What oil do people recommend for a Freelander rear diff in a BEC?
How much oil does the diff take?
MK9R
posted on 30/6/10 at 06:32 AM Reply With Quote
ep80 semi or fully synthentic. Comma do some thats reasonably priced and the local halfrauds stock it. You only need 1 litre
editted because i said 75-90 to start with, i got confused with the transferbox in a freelander, sorry too early
[Edited on 30/6/10 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 30/6/10 at 06:52 AM Reply With Quote
Like anyother hypoid diff it needs a Hypoid oil sometimes called an EP oil ie must be GL5 spec.
EP80 or EP90 or a multigrade such as EP75/90 to GL5
Red16
posted on 30/6/10 at 11:28 AM Reply With Quote
Good stuff, cheers lads... looks like I'm off to Halfords then.
Red16
posted on 30/6/10 at 03:08 PM Reply With Quote
Found a website with Landrover lubrication info, thought i'd add it for future reference.
http://www.dingocroft.co.uk/Rec_lubes_FRLNDR1.htm
Component : Freelander Rear differential
Capacity : 0.75 to 0.83L (1.6 to 1.75 US pints)
Specification : Texaco Multigear 80W90 ETL 7441 API GL5
Comma Oils : EP80901L -1L EP80905L - 5L
