Author: Subject: Laser or water cutting
mccsp
posted on 29/1/11 at 07:47 PM Reply With Quote
Looking to get some plates cut, with weight saving holes and mounting holes in aluminium approx 8mm thick. Which method is best and what is the minimum diameter hole that can be accurately cut?
Why do it the easy way, when I can do things my way!
andyw7de
posted on 29/1/11 at 08:04 PM Reply With Quote
Could'nt really comment on laser as i dont have one, but water cuts aluminium very well.
Aluminium is probably the most common metal we cut, especially thick aluminium, from memory we have cut up to 75mm thick but could cut thicker (up to 150mm), you wont get a laser to do that as far as i know.
smallest hole would probably be approx 2mm which is slightly bigger than the pierce
If you need a price let me know
cheers
Speed is just a question of money !
How fast do you want to go ?
plentywahalla
posted on 29/1/11 at 08:26 PM Reply With Quote
I used to run a laser profiler and aluminium was the hardest material to cut accurately. From what I remember it was something to do with the reflectivity of the surface which would occasionally 'bounce' the beam back. Plasma is brilliant on alluminium and we often found that the humble plasma cutter did a better job than the laser.
I have no experience of water jet but I would guess it is the best option.
koiking125
posted on 29/1/11 at 11:17 PM Reply With Quote
Try Fab-tech, there in Crowland just near Crowland Cranes, sorry dont know the number they will be in the book.
Kev
MK Owners Club Member (Frosty) No.1159
indykid
posted on 30/1/11 at 12:37 AM Reply With Quote
cheers
just out of curiosity, how far off perpendicular is the face of the cut on that sort of thickness?
anyway mccsp, if you want waterjet, i'm sure i won't be the last to recommend this man ^ .
absolutely fantastic service and very reasonably priced
andyw7de
posted on 30/1/11 at 01:11 AM Reply With Quote
The quality and squareness of the cut are all dependant on the speed of cut.
If you just want a rough finish that has a bit of an angle to it then its cut at a quicker speed hence its cheaper.
however i have cut some 75mm really hard tool steel which had to be vey square and have a good quality cut that would not require any further machining to finish.
We ended up with a cut speed of 2.8mm per minute.. very slow but the customer was well chuffed with it, but obviously not cheap at that speed.
cheers
trikerneil
posted on 30/1/11 at 07:49 AM Reply With Quote
Andyw7de waterjet cut some 25mm alloy for me and the finish was similar to a sandblast effect.
Andy has always given good service and price, I'd highly recommend him.
HTH
Neil
ACE Cafe - Just say No.
