Author: Subject: Scrap yard donor cars!
Chaz
posted on 23/5/11 at 09:15 PM Reply With Quote
I have worked out from A. Graham Bell's book of Forced Induction that a 50mm (approx) single throttle body will provide me with enough tuning capacity up to 250bhp. 1.8 zetec, Eaton m45.
Which donor cars, scrap yard cars or any other common vehicle has an easy to use throttle body of that size?
If you also know of most common cars found for injectors (350cc/min) or a good intercooler then that would be a help too!
Regards,
Chaz
MikeR
posted on 23/5/11 at 09:24 PM Reply With Quote
Did the MG rovers have an upgrade to 50mm?
Maybe some of the later special edition models have it as standard.
Hammerhead
posted on 23/5/11 at 09:28 PM Reply With Quote
52mm http://www.mgf.ultimatemg.com/group2/DIY/throttle_body_replacement/index.htm
CNHSS1
posted on 23/5/11 at 09:30 PM Reply With Quote
nissan 200sx runs 370cc injectors as std, cheap as chips as most want to upgrade.
ex-skyline intercoolers are large and good quality
nissan Sr20DET TB is 60mm as std iirc
check sxoc.com for classifieds.
matt_gsxr
posted on 23/5/11 at 09:34 PM Reply With Quote
Rover turbo, saab or volvo are good sources for large injectors.
For an intercooler, it can be tricky to get one that fits in the nose of a 7 as most are wide. Mazda Rx7, nissan sunny gtir might be worth a look and measure. Folk have fitted various ones, so worth a search on here.
austin man
posted on 23/5/11 at 09:55 PM Reply With Quote
Check out DRC Indy's archive hes done a turb o install I think I have some pics of the Honda S2000 engine with turbo in my Archive that runs 380 at the wheels
Volvorsport
posted on 23/5/11 at 10:44 PM Reply With Quote
volvo redblck turbo - 330cc/min injectors
massive intercooler , 57mm throttle body .
intercooler wont fit a 7 tho .
www.dbsmotorsport.co.uk
getting dirty under a bus
coyoteboy
posted on 23/5/11 at 11:25 PM Reply With Quote
Celica GT4 or MR2 turbo:
Throttles 55-62mm depending on model and year, injectors are 440s or 540s depending on model. Should be able to get throttle body for ~40 quid on fleabay, injectors and rail for ~30 or 60 depending on year.
Chargecoolers on the better models (GT4, not mr2) but a full setup will cost you £200ish and the pre-rad won't fit up front in a 7-esque. The air to air intercoolers from the 185 and mr2 are extremely low pressure drop and quite effective for a short time, but heat soak fairly fast in their top mount location, might be acceptable up front?
[Edited on 23/5/11 by coyoteboy]
ChrisW
posted on 24/5/11 at 12:05 AM Reply With Quote
The MR2 intercooler is mounted on the side, behind the n/s air intake!
Chris
coyoteboy
posted on 24/5/11 at 12:14 AM Reply With Quote
I know, but I can't be arsed explaining where they are in all models using the same engine and IC combo (St165, st185, st205, mr2 MkII v1,2 and 3), my point being the ATA intercoolers are not bad but a tad small (it's the exact same IC core), rather than to document their location on all cars! In the GT4 they're top mounted and interwarmers rather than intercoolers.
big_wasa
posted on 24/5/11 at 06:39 AM Reply With Quote
2.0 tb is bigger, that or a cossie TB
mad-butcher
posted on 24/5/11 at 06:43 AM Reply With Quote
Is a Mitsi Pajero intercooler any good, has an electric fan mounted underneath as well,
Tony
