<<  1    2  >>
Author: Subject: FOR SALE: EVERYTHING inc. ZX12 engine, wheels+R888's, MK bodywork
eznfrank
posted on 29/6/11 at 10:20 AM Reply With Quote
EDIT - NB. If you've sent me a message or responded on here I'll respond properly tonight - I've been completely inundated with requests a few of which are for the same part so will respond to all queries this evening
i was going to do this in dribs and drabs but seems a bit pointless. For personal reasons I have decided to discontinue my build and strip the car back for parts so I have lots for sale. I will elaborate further when I get a minute but parts and prices as follows:
EDIT - On the smaller bits and pieces where postage is only a few quid I'l include that in the price. The bigger bits will either be collect only or I could deliver dependant on location
ZX12 A1 Engine with shortened sump and modified pickup, includes ECU, regulator and a modified engine only loom. The loom has had all the lights etc stripped out, the loom was modded by me and does work but I have to admit it's not the best wiring. I can include a very clear copy of the wiring diagram. Also includes ignition barrel with two keys, avoiding need for resistors etc. The engine was sourced from Malc at Yorkshire engines and from memory has 2300 miles on it. Looking for £1450
Ceramic coated steel manifold made by S&S headers in the states. Made for a ZX12 but IIRC would fit R1 and Gixxer, but will need to check. Includes collector. £250 (cost closer to £500 with import duty from US) these are not your average manifold
Power Commander III for above £125
Clocks for the above with a custom one-off ali fascia made by Martin Keenan - £130
75mm ITG filter and baseplate for the above £70. Could use basplate as template to adapt to fit most BEC's
Prop adaptor for zx12 £35
Wheels & tyres. Set of black multi spoke 15" alloys with SG compound R888's. Brand of wheel TBC. Have been fitted and slight paint rubbed off around wheel nut holes. Never used other than wheeling in and out of the garage. £500
Ali Petrol tank made by MK, with swirl pot and & ZX12 fuel pump. I would sell these seperate but the tank was made specifically for this pump. £175
Seats - 2 fibreglass triton style (not triton AFAIK) seats. Both in decent condition although slight usually swirling and light scrathes. Have been loosely trimmed with U trim on the edges but would need to be made permanent for IVA I guess. £160
Prop modified by MK, will check length tonight £60 - Provisionally sold
3.62 LSD Sierra 7" Diff, bolt on type £150 - SOLD
Bolt on driveshafts to match Diff above £70 - SOLD
Pair of Sierra front hubs, bought as brand new, never been used other than pushing backwards and forwards. reamed by MK £70 - SOLD
Rear Sierra hubs with new bearings and races £30 - SOLD
Front and rear Sierra calipers & discs. Calipers have been re-manufactured by Bigg red and have a red polymer coating. Will double check fitting tonight but believe fronts are XR4i vented and rears are xr4x4 solid. £140 - Provisionally sold
MK Nose cone in black, has been fitted and had indicators on it on the circle flat spots. Slight scuff on upper lead edge £70 - Provisionally sold
MK Bonnet with bulge in black, has been fitted and had the rear bonnet clips drilled out, plus two small holes near OSF bonnet clip. Bulge opening has been meshed. £80
13" Mountney steering wheel, with a free Sierra steering wheel thrown in to get you through IVA. Can include boss adaptor for the Mountney, and horn adaptor. £45
Modified steering column to suit MK £30 - Provisionally sold
modified Steering rack to suit MK (modified by MK) £30 - Provisionally sold
MK Reverse box, ring gear, cable and button. Never used £250
Full set of MK Wishbones £100 - SOLD
other bits and pieces I will put a price on asap but feel free to make an offer in the mean time.
Speedo healer - SOLD
Acumen gear indicator - SOLD
Battery
MK gear linkage inc. turned Ali knob - provisionally sold
Interior panels
throttle cable
Clutch cable from MAC - SOLD
Front Cycle wings in black
Rear arches in black - have been cut for lights and have orange oval indicators sikaflex'd into them
Bonnet catches - SOLD
Sierra Handbrake -SOLD
Leather look handbrake gaitor and chrome surround
Tonneau cover for MK with roll bar without back stays
Scuttle - Provisionally sold
Shocks and springs - will check brand but the standard ones that come with MK - SOLD
rear MK Uprights - SOLD
Immobiliser
handbrake cable
CBS Wiring module and cover
Fan
[Edited on 1/7/11 by eznfrank]
neilp1
posted on 29/6/11 at 10:35 AM Reply With Quote
u2u handbrake gaitor, handbrake cable, throttle cable and fan
wylliezx9r
u2u sent
George Best
welderman
posted on 29/6/11 at 11:18 AM Reply With Quote
interested in
Speedo healer
Battery
throttle cable
Bonnet catches
Sierra Handbrake
handbrake cable
Thank's, Joe
I don't stalk people
jossey
posted on 29/6/11 at 11:48 AM Reply With Quote
handbrake
Prop if right length or close :O)
wishbones if they fit my locost :O)
cheers
David Johnson
posted on 29/6/11 at 11:57 AM Reply With Quote
Aaron, sorry to see you're selling up mate.
Interested in Sierra Calipers and discs, both front & rear.
Phil
[Edited on 29-6-11 by Hellfire]
hobzy
posted on 29/6/11 at 12:00 PM Reply With Quote
VERY interested in the wheels/tyres but am way down south.
Do you have a pic of one of the wheels so I can see the design please?
mcerd1
posted on 29/6/11 at 12:05 PM Reply With Quote
sounds like the same ones I've got...
the fronts should be 260mm vented (XR4i or 2.0 ABS discs should be right for normal sierra hubs)
the rears should be 253mm solid dics (XR4i, 2.0 ABS or XR4x4 discs should suit)
these are also the same brakes used by mk3 granada's, but with 5 stud discs
[Edited on 29/6/2011 by mcerd1]
posted on 29/6/11 at 12:06 PM Reply With Quote
If you're interested, I can get them from Leeds down to Junction 27 of the M1. LCB courier stylee..........
Phil
Doctor Derek Doctors
posted on 29/6/11 at 01:09 PM Reply With Quote
U2U sent regarding the Nose Cone, Scuttle and Steering Column
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
cloudy
posted on 29/6/11 at 01:16 PM Reply With Quote
Interested in wheels an tyres - pending a photo or model
www.warnercars.com
eznfrank
posted on 29/6/11 at 01:29 PM Reply With Quote
Hi mate, here is a not very good photo of the wheels and tyres, can get a better one off home PC tonight
https://www.facebook.com/photo.php?pid=4790723&l=6a52bd7794&id=573426945
hucky
posted on 29/6/11 at 01:59 PM Reply With Quote
u2u sent in reguards to suspension
brookie
posted on 29/6/11 at 03:41 PM Reply With Quote
intrested in the Acumen gear indicator
pekwah1
posted on 29/6/11 at 04:06 PM Reply With Quote
u2u regarding seats!
hobzy
posted on 29/6/11 at 04:08 PM Reply With Quote
Thanks for the pic, let cloudy have first dibs as I'd have to paint out the red stripe and wont have the cash for a couple of weeks it seems.
eznfrank
posted on 29/6/11 at 06:26 PM Reply With Quote
Photo of alloys
and seats
[Edited on 29/6/11 by eznfrank]
gaz_gaz
posted on 29/6/11 at 07:44 PM Reply With Quote
Phil
and i could get them from J27 of the M1 down to Sussex if it helped at all,
also sent the op a u2u
davestarck
posted on 29/6/11 at 08:38 PM Reply With Quote
U2U regarding tonneau cover
blakep82
posted on 30/6/11 at 09:00 AM Reply With Quote
what type of immobiliser is it?
________________________
james h
posted on 30/6/11 at 02:39 PM Reply With Quote
u2u re: rear uprights and set of wishbones
James
dibble10
posted on 1/7/11 at 09:54 AM Reply With Quote
Hi
Can you give me a price for the full zx12 setup - engine, loom, clocks, prop adapter etc.....
893cc Blade Engined 7 style.......thinking of ZZR1400 transplant???
RK
posted on 2/7/11 at 01:02 AM Reply With Quote
Do you have a dash blank?
Also interested in the immobiliser.
DRC INDY 7
posted on 2/7/11 at 06:16 AM Reply With Quote
also can i see a picture
Cheers Dale
FatChapChipChop
posted on 2/7/11 at 11:56 AM Reply With Quote
U2U sent - Fuel Tank
Drive fast, don't look back!
<<  1    2  >>
