theconrodkid
posted on 17/12/15 at 08:38 PM |
sparky type q
I am upgrading my garage lighting soon,can i run 2 X 4ft (30 watt ?) flourescent lights from a single switch or do i need one per fitting ?
who cares who wins
pass the pork pies
posted on 17/12/15 at 08:47 PM |
Easily. Light switches are typically rated at 5 amps, which is 1200 watts of lighting.
posted on 17/12/15 at 09:29 PM |
There are also 10a switches. Not a problem.
gremlin1234
posted on 17/12/15 at 09:44 PM |
only need two switches if you want to have one or other or both on.
worth looking at led lighting too
theconrodkid
posted on 18/12/15 at 08:48 AM |
cheers guys,i was worried about phasing ? or whatever it,s called,in my previous place you could only get half the lights to work at one time.
[Edited on 18/12/15 by theconrodkid]
who cares who wins
pass the pork pies
sparkyj83
posted on 18/12/15 at 07:20 PM |
q
You will be fine all light switches are rated at 10 amp + .you will be fined your lighting will either be a 6 amp or a 10 amp mcb two Flu's
will be fine. try and go for cool white led tubes the light output is great for garage use
[Edited on 18/12/15 by sparkyj83]
theconrodkid
posted on 18/12/15 at 08:13 PM |
cheers Sparky
who cares who wins
pass the pork pies
