dave r
posted on 9/1/16 at 12:30 PM |
pressure regulator
air pressure regulators..
is it possible to get a pressure regulator for air, that will track another pressure.
so that you could in theory have your set pressure say 1 bar above at all times
i need to be able to put air into a pipe at work, at a set flow regardless of the pressure in the pipe
pipe pressure varies from maybe 4 to 8 bar
at the moment we have a needle valve, and suffer from a drop off in flow as the pressure increases
think something similar to a fuel regulator for the injectors on a turbo/supercharged car works in a similar way ?
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
sprintB+
posted on 9/1/16 at 03:06 PM |
I think you may be looking for a pilot operated regulator. Takes a feed from the pipe to stabilise and keep constant the flow you require. Remember
that flow and pressure are two different things.
dave r
posted on 9/1/16 at 04:08 PM |
thanks for that.
i realise that flow and pressure are different, but for a given hole and a constant pressure drop you get a constant flow
v8kid
posted on 9/1/16 at 07:18 PM |
Mks flow regulators are very accurate and robust. You will need a plc to control
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
dave r
posted on 10/1/16 at 08:43 AM |
plc isnt an option,
i know its do-able purely mechanicaly
daviep
posted on 10/1/16 at 10:17 AM |
Something like this maybe? You don't mention size/volume so this is quite small.
PRESSURE COMPENSATED FLOW CONTROL
A call or email to the technical support at Parker, Norgren or SMC should also sort you out.
Davie
dave r
posted on 10/1/16 at 02:46 PM |
looks a possibility.... we are looking at up to 10l of air a min
