hazardpro
posted on 28/3/18 at 03:47 PM |
CBS Wiring module - savage switches - questions/help please
Hi all
Looking for people who are running the CBS wiring module.
Have some specific questions regarding wiring indicators and hazards and also lights please.
Im finding their wiring diagram confusing to say the least.
So first issue..... im running savage switches....
I have 3 switches for the lights:
side light, headlight, full beam
Based on the CBS module there is one feed for the side and headlights.... (L4) - so checking L4 , this is a permanent live.... so that means my side
lights would be on all the time.... which is going to be no good.....
So can anyone using the CBS and savage switches please let me know how they wired those up?
Second issue, hazard lights and turn signals.
Ok no idea on this one.... the CBS module says it has Hazard unit and flasher unit built it. But it has one feed for the indicators (L7) - ive checked
that and it does not give any voltage (probably because I have to wire up the hazard part?)
There is also U3 which states 'feed for hazard switch terminal 49a'...
Now I have the savage hazard light switch.....but dont know how that supposed to be wired up to work with the CBS module.... and I wanted to have 2
on/off buttons for the indicators (which I will mount to my steering wheel). Again dont know how to wire those up.
I guess id need to wiring it up so it would not be possible to hit the left indicator btn and right one - resulting in both left and right indicators
going at once, so pressing one would need to cancel the other..... I think..... lol
Its at this point my brain goes into complete meltdown lol
Would be very grateful for any help
H
CBS Wirinbg Module wiring diagram
[Edited on 28/3/18 by hazardpro]
jelly head
posted on 28/3/18 at 05:56 PM |
Didn't use a cbs module but the diagram on the below site works for using savage switches for indicators etc:
http://bassettsbuilddiary.blogspot.co.uk/2009/02/
big-vee-twin
posted on 28/3/18 at 08:13 PM |
Not used one of these but I think you mean pin 14 for the lights.
This a permanent live feed you take to your switch, then from other side of switch to lights.
Again pin 17 outputs live to your indicator switch common then onto your indicators.
http://www.triangleltd.com
