Author: Subject: Noisy HP fuel pump
40inches
posted on 19/4/18 at 02:58 PM Reply With Quote
Noisy HP fuel pump
Out for a run today, 24degrees
After about an hour and a half the HP pump started squealing,then the engine lost power above 5000rpm
I think I know the answer: New pump?
Bit disappointed,not a cheap pump and only done about 1500 miles
owelly
posted on 19/4/18 at 03:11 PM Reply With Quote
Check filters and regulator first.....then pump.
http://www.ppcmag.co.uk
theconrodkid
posted on 19/4/18 at 03:13 PM Reply With Quote
as above, or an air leak
who cares who wins
pass the pork pies
40inches
posted on 19/4/18 at 03:31 PM Reply With Quote
Thanks chaps. I'll check it again tomorrow. Can I take it that if it's OK cold, but squeals when hot,it is the pump?
BaileyPerformance
posted on 19/4/18 at 05:53 PM Reply With Quote
most injection pumps must have a larger input/feed than the outlet. Normally 12mm feed 8mm out.
The pump must be gravity fed.
If your feeding the pump with the normal 8mm pipe it will nor work, your pump is now dead.
r1_pete
posted on 20/4/18 at 09:22 AM Reply With Quote
Must have been a bad day for pumps yesterday, my XJR1300 did exactly the same, its now normal sound priming cold, growls like an old grizzly when its hot....
40inches
posted on 20/4/18 at 10:14 AM Reply With Quote
Bad day all round Pete
Tried it this morning, sounds fine static, squeals like a stuck pig when hot!
I think the pump may be dying, although it is fed from a swirl pot with 12mm connection, the fuel temperatures yesterday went ballistic, I could hear the fuel "boiling"in the tank The swirl pot (in the engine bay) got up to 80degrees with 60 degrees in the tank.
I think a complete rethink of the fuel system is in order
melly-g
posted on 20/4/18 at 03:15 PM Reply With Quote
I am having exactly the same issue, only just changed to fuel injection pump has done about 200 miles and it sounded awful yesterday louder than the exhaust.
Ran for a short time today, no noise at all!
I think I may have to look into a fuel cooler!
40inches
posted on 20/4/18 at 05:03 PM Reply With Quote
I will be deleting the swirl pot, I think that is the source of the heat. Not enough room for it outside the engine bay.
I am going to put the HP pump near and below the tank and feed it with the lift pump.
tims31
posted on 20/4/18 at 08:59 PM Reply With Quote
On my Fury I have the fuel pump under the fuel tank at the rear of the car and then a line that runs up to the engine bay, through a HP filter and then onto the fuel rail and back to return with no issues. Not sure if you can site your pump near the tank?
Build: http://www.martinsfurybuild.co.uk/
chris
posted on 20/4/18 at 09:36 PM Reply With Quote
i am fitting a new high pressure pump into my in tank swirl pot and pump its a fuel pump and swirl pot from a v8 range rover but to get over 250bhp i have had to change the pump cos its not strong enough got a walbro that can pump up to 8 bar apparently
[Edited on 20/4/18 by chris]
