Author: Subject: 2008 Hayabusa engine
Triggerhappy
posted on 22/8/08 at 12:10 PM Reply With Quote
Plan to build an seven in near future.
My goal is to use the latest Busa engine.
Has anybody built an seven with it yet?
The 2008 model is fitted with imobilizer and i supose it would give me an hard time if i don´t have the complete bike loom, ignition key and dash.
It also have lambda on board, suppose cloosed loop.
Anybody with experience of this electronic lump?
I also try to get confirmed if the existing drysump systems will work.
Nova engineering and TTS say i looks like it would work....not firmly confimed...any body how really knows?
posted on 22/8/08 at 01:49 PM Reply With Quote
Speak to Chris Mason - he's using one on his latest project
Triggerhappy
posted on 22/8/08 at 03:10 PM Reply With Quote
Thanks for replying.
I checked his site out and he seems to be in an earlier stage in his build to face all engineproblems.
worX
posted on 22/8/08 at 05:30 PM Reply With Quote
That might be the case, but he didn't rush in to his engine choice and did a lot of investigation first.
He may still have some knowledge/advice that is valuable.
Regards,
TimC
posted on 22/8/08 at 05:58 PM Reply With Quote
There's nothing quite like 2nd hand info but I think the man in question is away with the family, so...
Fesycresy has indicated to me that the dry sump kits do fit.
Jason Fletcher
posted on 22/8/08 at 06:40 PM Reply With Quote
Hi there
I have just completed a 7 build with a 2008 Busa engine. Its the dogs nuts and would definatly recommend it!
Although the sump pan differs slightly on the 08, the current Nova dry sump system still fits along with the oil pump. The main output shaft where the sprocket goes on is bigger so the current ones wont fit but nova happened to have the broach to make one. All engne mounting points are the same. I totally took the loom apart and took out all the crap that the bike has like the things stand and clutch sensors. Theres no way I could find out how to get rid of the chipped key so I fitted it in the car by taking the chips out the keys and fitting them in the car ones. I'm glad I did as it works great!
Theres a few pics in my archive but if you need any more info at all let me know.
Jason
Before SVA with nasty repeaters and exhaust wrap
[Edited on 22/8/08 by Jason Fletcher]
Paul TigerB6
posted on 22/8/08 at 07:39 PM Reply With Quote
did you say something Jason?? I never got any further than your Avatar!!!
Jason Fletcher
posted on 22/8/08 at 08:01 PM Reply With Quote
Paul
I bet she's as dirty as your avtar eh.. Well almost.
J
Triggerhappy
posted on 22/8/08 at 08:55 PM Reply With Quote
GREAT INFO!!!
Many thanks Jason.
Any other Busa-08 findings are moore than welcome.
Paul TigerB6
posted on 23/8/08 at 12:10 AM Reply With Quote
Originally posted by Jason Fletcher
Paul
J
Well i guess you will have to tell us mate!! What do you recon??
Jason Fletcher
posted on 23/8/08 at 08:27 PM Reply With Quote
One other thing worth mentioning is that A.P do a 14mm master cylinder which is a good match to the Nova clutch slave. It's very proportional and does not snatch like the more common 5/8 bore ones are supposed to.
Jason
