Latest Projector headlights £24 discount!
russbost - 27/9/12 at 11:51 AM
These are our very latest projector headlights, they provide both dip & main beams within one tiny unit, 42mm lens, 86mm wide, & 76mm high, on Ebay & on the website at£109.95 - to locosters I will do the first 10 orders at £89.95 per light (+ P & P) - I need to get some out there & get them noticed & known about!
Combined dip/main projector
Combined dip/main projector 2
What's more the brackets you see them pictured with are normally £4ea extra, I will throw those in the deal for free, so that's a total of £24 off the normal retail or nearly 25%. This is a one off offer, not to be repeated!
They are NOT "E" marked but have a flat beam pattern & are fully UK road legal, we've had a set thro' IVA & if you have a fussy tester then you'll need to cover the front edge as believe it or not it's a fraction too tight a radius, but beam patterns are absolutely fine! They are what we are now using on the Furore & I've used them quite a lot at night at high speeds & they throw a brilliant light.
[Edited on 27/9/12 by russbost]
