New Topic New Reply
Author: Subject: Kit Car Services - turning and more....
flak monkey
posted on 28/7/09 at 08:21 PM Reply With Quote
I am now in a position to offer a few useful services to fellow kitcar builders and others.
My website is http://kitcarservices.co.uk which outlines most of what I can offer, but if you are after help with something which isn't listed, get in touch and I can probably help out.
These services basically include:
Turning (up to 19" diameter) - this could be anything from suspension spacers to custom hubs (some examples below).
Electrical and electronics work
Donor part reconditioning (including type 9 rebuilds at competitive prices)
Throttle body respacing (including fuel rails)
CAD work for laser cutting
and all sorts of other things.
Prices will be given on a job by job basis.
Some examples of turning:
* Blanking plugs for throttle bodies
* Bushes made to your requirements (aluminium, brass, nylon, bronze etc)
* Spacers (for suspension, rose joints etc)
* Propshaft spacers - made to your requirements. Properly bossed and recessed to ensure concentricty
* Hubcentric wheel spacers made to your specification
* Camber adjusters to your sizes (for front or rear custom wishbones)
* Threaded tubes for wishbones - with your choice of thread including M18x1.5 for transit track rods)
* Custom aluminium gearknobs
* Indicator stalks
* Custom made aluminium fuel rails, aluminium extrusion, drilled to your requirements for injectors, end tapped 3/8BSPT, ready to fit brackets
* Sierra upright tapered adaptors eccentric or concentric, your choice
* Concentric clutch cylinder spacers to your requirements drilled to suit your application
* Custom alternator pulleys single vee and poly vee
* Custom water pump pulleys as above
* Trigger wheel fitting pinto and crossflow including trigger wheel – laser cut trigger wheels and pulley modified to fit your application. Trigger wheel fitted on turned disc to ensure concentricity
* One off hose joiners
* Custom hubs
* Thread cutting available, both metric and imperial
and much more
Some pictures of a selection of the bits I have made:
Duratec billet fuel rail
Simple ali spacer
Aluminium spacer
Aluminium spacer
Type 9 cable speedo blanking plugs
Type 9 speedo blanking plugs
GSXR Injector blanking plugs
GSXR injector blanking plugs
And the above fitted
Throttle body adpators
TB Adaptor
TB Adaptor
[Edited on 29/7/09 by flak monkey]
Sera
http://www.motosera.com
New Topic New Reply
