Prop Shaft Catcher Plates
These parts are now available for purchase and next working day dispatch.
Prop Catcher Plates
Prop Catcher Fully Closed
Prop Catcher Fully Open
Designed to allow various mounting positions for fixed diff or live axle arrangements, two or four bolt mountings and if you are not keen on the
overlap the excess can be trimmed as desired. Material is 3mm MS powdercoated matt black.
NOTE: Horizontal distance between hole Centers 118mm and they are clearance for M6 but can be drilled out if needed (apologies this is missed this off
the drawing!).
Some mounting scenario's depending on chassis design and prop position may require the plates to be spaced off the chassis members, eg by
threaded bar, long bolts or spacer pillars.
A pair of plates to do one end of your prop as shown above is £10 + £3 p+p.
2 Pairs to do front and rear £20 + £3 p+p.
To purchase please send a paypal payment as a 'purchase of goods' to bboyfastdan@hotmail.com with a note to say what the payment relates
to.
Dan
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
