New Topic New Reply
Author: Subject: A.L.D products and services
Andrew@ALD
posted on 23/3/12 at 05:57 PM Reply With Quote
A.L. Developments Fabrication and Engineering here
What i can offer you is CNC machining and Fabrication in Mig and Tig
We also do cylinder head work at a good price
As seen in Redline mag with Robs RS2000, Robs car had many of my custom made parts and products
Lightening & Balance Flywheels.
Connecting Rod Modifications i'e
Oil jet drilling, Bushing, Machining big & Little ends.
Crankshaft Modifications and Repairs
i'e Grinding & Tuffriding etc.
Cylinder head repairs
Skimming and Pressure testing.
Block Modifications i'e
Ford Zetec for Turbo conversion i'e Silver, Black and ST170 for Turbo conversions
Ford ZVH ( CVH head on Zetec short block )
2.0 to 2.3 I4 conversion
2.2 stroker block conversions for VAG 20v 1.8T engine
also Rebores, Cross hatch hone, skimming, Extra breather modifications.
Custom Inlet manifolds/8 Injector manifolds and Throttle body/Throttle bodies conversions
Motor bike throttle bodies and bike carb conversions for cars engine
Adaptors for bike carb's/ITB's to use Jenvey Trumpets
Piston modifications i'e
Skimming, Valve pockets.
Custom adaptor plates.
Custom breather fittings.
Brake disc and caliper fitting kits
Custom fuel injector holders and rail holders.
Modified valve covers/Rocker cover i'e
Extra breather
Sump modifications
Dry sump modifications
Dry sump modifications for FWD Zetec/ZVH
Custom Strut Braces
Beam and Track control arm modifications i'e
adjustable, stiffening, & Custom
Modified water pumps i'e
CVH to Zetec engine conversion pump, Electrical water pump housing modifications
Plus loads more, Please contact us for prices
See http://www.aldevelopments.com/ for more info but i will also post some pics
Heads have been tested on a borrowed Superflow 110 but am now building my own flow bench that is capable of flowing a cylinder head/s to 600cfm's at 28in test pressure.
Audi S3 small port APY 20v head
Some pictures of a Golf V5 head
Taken from the just the Exhaust side of the 20v head
Mk5 RS 2000 head
CVH head
Also inlets and throttle bodies can be done
Head prices
8v heads starting from £300
12v heads starting from £350
16v heads starting from £400
20v heads starting from £500
24v heads starting from £600
Also other things none head work
Lightened, balanced flywheels from £100
Brake conversion ( FFRS onto Mk5 RS2K ) from £100
Custom modified dry sump for Mk4 Escort from £50 sump not supplied
Custom manifold for I4 from £100
Valve cut outs or skimming of pistons from £20 piston
Custom speed sensors from £20
Modified water pump housing for electrical water pump from £50
ATCA from £100
Baffled sumps from £80
Solid tappet insert conversions from £150
4 Bolts CVH to Zetec engine mount £30 if mount supplied.
More to come
New Topic New Reply
