New Topic New Reply
Author: Subject: Updated prices on Aerosols!!!
Razzakit
posted on 24/4/14 at 07:04 PM Reply With Quote
All prices now including VAT to make things easier
Delivery is £3 for 1 can Royal mail 2nd class.
£10 for 4 cans courier 1-2 working days.
Maintenance spray 1 x 500 ml £4.50 4 x 500 ml £17.60
(Ideal for cleaning and protecting most electrical equipment. Other applications include the lubrication of small or inaccessible components such as locks or hinges, the loosening of rust scale before wire brushing, and as a damp-start for motor vehicles)
Copper grease Anti seize 1 x 500 ml £5.40 4 x 500 ml £21.00
(Fuchs Copper anti-seize is effective as a lubricant, penetrant and as an anti seize paste for applications such as nuts, bolts or flanges. It provides excellent separating properties, reduces wear up to 275 deg C and is effective as a releasing agent up to 1100 deg C)
Silkut (Cutting fluid) 1 x 500 ml £7.80 4 x 500 ml £30 .00
(A high performance lubricant for threading, reaming, drilling and broaching in a wide variety of materials including free cutting steels, stainless alloys, non-ferrous metals, nickel alloys and titanium)
Chain lube 1 x 500 ml £5.30 4 x 500 ml £20.00
(Chain Lube High performance lubricant designed for all chains not fitted with an automatic lubrication system. contains a high viscosity lubricating base oil along with extreme pressure and anti-wear additives for superb chain protection. penetrates pins and bushes, reduces chain wear, provides excellent corrosion protection and reduces friction)
Renoclean 1 x 500 ml £4.60 4 x 500 ml £18.00
(High performance deep penetrating, fast acting, fast evaporating
solvent based degreaser designed to remove grease, oil, dirt and grime
from engines, tools, equipment and hard surfaces. Evaporates to leave clean,
dry surface. can be used on ferrous and non ferrous metals and most plastics)
Silkopen 1 x 500 ml £6.50 4 x 500 ml £25.00
(Produces a jet spray of penetrating fluid foreffective, quick release of seized and corroded metal parts.
Suitable for use on fasteners, studs, valves, couplings etc. It is intended primarily as a dismantling aid to help free off seized or corroded components. FUCHS SILKOPEN AEROSOL contains powerful solvents and dewatering aids to enable the fluid to “creep” into the most confined spaces)
Card payment accepted or you can pay in cash if you want to travel to Southport or Halsall.
We currently don not use paypal as there fees are too high at the moment and we make very little on these products as they are.
Please p.m. with your orders or email me at ryanct22@hotmail.co.uk
Thanks for looking Ryan.
[Edited on 24/4/14 by Razzakit]
[Edited on 25/4/14 by Razzakit]
New Topic New Reply
