reck
posted on 6/12/05 at 07:32 PM |
running a loom
Hi all
can you help, i know you should not run the electric loom along side fuel lines but how close is exceptable????I want a parallel run about 120mm apart
along the transmision tunnel. Any comments.
phoenix70
posted on 6/12/05 at 07:54 PM |
I don't think there is anything specific in the SVA manual in this regards, but I can't seen any problem with that spacing. In fact I run
both my fuel pipe and electrics down one side of the tunnel with about 6cm between them..... although my car hasn't been through the SVA yet.
Later
Scott
BKLOCO
posted on 6/12/05 at 08:05 PM |
All I could find in the SVA bible was that they should not share the same clips.
However most people recomend running them on opposite sides of the tranny tunnel.
silex
posted on 7/12/05 at 05:59 AM |
And it would make safety sense to run the harness above the fuel lines (in case of leaks).
Murphy's 2 laws
1. If it can go wrong it will
2. In case of emergency - refer to rule 1.
reck
posted on 8/12/05 at 06:22 PM |
Wiring and fuel lines
Thanks for the words of wisdom, I'll feel happier now you dont think im doing anything to daft.
