flak monkey
posted on 18/1/09 at 08:58 AM |
Throttle return springs
What has everyone else done who is running throttle bodies with regards to throttle return springs?
I currently only have the springs which are on the tbs themselves and i dont know if thats enough. If not what has everyone else done?
Sera
http://www.motosera.com
Steve Hignett
posted on 18/1/09 at 10:01 AM |
Bike Engine and therefore Bike Carbs, but you get the idea
I did them this way round Dave, because once setup a simple change of the spring stiffness alters the feel in no time...
omega 24 v6
posted on 18/1/09 at 10:14 AM |
Just left mines as is at the moment David although seeing as they were meant for wrist action they feel quite light on foot action if you see what I
mean.
As long as they're not sticking try them first and modify later.
stuart_g
posted on 18/1/09 at 10:51 AM |
I put a normal spring on where the return throttle cable would be. Just drilled a small hole for the spring to sit in.
![](/galpreviews/a871500-Extra return spring.JPG) ![Rescued attachment Extra return spring.JPG](/gallery/a871500-Extra return spring.JPG) Rescued attachment Extra return spring.JPG
piddy
posted on 18/1/09 at 04:50 PM |
I'm just running mine as was seems fine to me.
flak monkey
posted on 18/1/09 at 04:51 PM |
Just been for a drive and the throttle seems light, but returns ok. Might just add one on to be on the safe side.
I like your idea stuart, will see if I can fit something in along those lines.
Sera
