Poll: Fuel and brake line fixing - poll [View Results]
Rivet
Rivnut
Author: Subject: Fuel and brake line fixing - poll
speedyxjs
posted on 13/9/09 at 10:49 AM Reply With Quote
What is the best way to fix the fuel and brake line clips?
Obviously rivet would be easier but makes removal more difficult.
[Edited on 13-9-09 by speedyxjs]
big_wasa
posted on 13/9/09 at 10:56 AM Reply With Quote
I would avoid to many rivnuts.
The oem clips look ideal and the easiest to use.
Drill hole and plonk the bush in, stick clip into that .
I would try them if starting again.
[Edited on 13/9/09 by big_wasa]
tomgregory2000
posted on 13/9/09 at 10:57 AM Reply With Quote
Rivet these on
Cable tie bases
then just use a cable tie
gottabedone
posted on 13/9/09 at 11:03 AM Reply With Quote
I used these ^^^ it's also far easier if you have to take the lines off for any reason as you just snip the cable tie. I also used them for my loom - great for hiding the loom if you put them on the underside of your rails. Also good where the loom and cabling goes around corners.
omega0684
posted on 13/9/09 at 11:05 AM Reply With Quote
Originally posted by tomgregory2000
Rivet these on
Cable tie bases
i don't think any inspector would be impressed if he saw cable tied fuel lines!
do it properly, for fuel lines use rubber insulated p-clips rivetted to the chassis
for brake lines, do the same as fuel lines or use the clips big wasa has pictured
blakep82
posted on 13/9/09 at 11:27 AM Reply With Quote
stolen from CBS catalog, but a cool tip
________________________
posted on 13/9/09 at 01:55 PM Reply With Quote
Rivet these on
Cable tie bases
Bases have to be screwed on or is a fail, much better and quicker use OEM style plastic pop in clips, as big_wasa suggested. You can also get similar types that clip both brake and fuel lines or twt brake lines.
