Author: Subject: pipe elbows to make a manifold, possibly steam pipe
PuppiesBalls
posted on 1/7/10 at 01:15 PM Reply With Quote
Does anybody know where i could get hold of some elbows & pipes to make a manifold?
Ideally 35mm i.d.
I have heard 'steam pipe' which is nice & thick is perfect for manifolds anybody had any experience with this?
welderman
posted on 1/7/10 at 01:16 PM Reply With Quote
316 stainless here
posted on 1/7/10 at 01:20 PM Reply With Quote
Fiat Ducat upper outer steering column here
daviep
posted on 1/7/10 at 03:04 PM Reply With Quote
What kind of manifold? inlet, exhaust, turbo?
"nice and thick" is not normally a positive description when building a lightweight sportscar
PuppiesBalls
posted on 1/7/10 at 03:08 PM Reply With Quote
turbo manifold
daviep
posted on 1/7/10 at 03:23 PM Reply With Quote
Originally posted by PuppiesBalls
turbo manifold
I'd still go with 316 stainless components such as THIS
v8kid
posted on 1/7/10 at 04:02 PM Reply With Quote
Stainless is easy to weld too. I used normal mild steel mig wire 'cos stainless wire was too stiff for my welder and the weld pool picked up enough additives from the stainless pipes to remain rust free for 2 years now.
Runs red hot so it should easily be strong enough for a turbo manifold.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
madteg
posted on 1/7/10 at 06:48 PM Reply With Quote
What turbo are you going to use. If its a TD04 i have a spare turbo flange going in 316 st/st.
