Author: Subject: cut down loom and o.e ecu any good?
legend
posted on 19/11/16 at 12:43 PM Reply With Quote
eBay Item Hi anyone using a oe zetec ecu with cut down loom to run zetec on carbs ? are they any good?
[Edited on 20/11/16 by legend]
DW100
posted on 19/11/16 at 12:57 PM Reply With Quote
I guess it will make the engine run, but there are no load sensors connected. I.e throttle position, MAF, MAP or lambda so is never going to advance the timing.
You would be better of with something like the nodis system
