Author: Subject: st 170 megasquirt base map
Gre3D
posted on 15/2/17 at 11:54 AM Reply With Quote
hi guys,
i'm almost ready to fire up the st170 zetec i'm building into my locost at the moment,
i was wondering if anyone has a good base map i could use to make the whole process a bit more fluent?
i'm running ms1 with msextra, i added some bits so i could dump the ford edis.
i'll be using the vvt-pro controller from ME,
on 45mm ITB's,
a bit of a flowed head, nothing mayor,
a little bit raised compression,
just to give you guys an idea.
i've allready found a blocktop zetec on itb's rolling road mapped file which i think will be a good starting point.
but maybe someone on here could help me out with an actual st170 file?
thanks!
chris
posted on 15/2/17 at 11:49 PM Reply With Quote
i am also just about to fit a megasquirt to my st170 but its the ms3 from Extra Efi who supply a base map with it i think
Gre3D
posted on 16/2/17 at 07:11 AM Reply With Quote
great, good luck to you!
i found some maps on here btw. http://www.elpaulio.co.uk/megasquirt.html
should give me a good starting point i think
