Author: Subject: Black top system
the_big_1
posted on 7/3/17 at 09:03 AM Reply With Quote
Black top system
Hi guys,
I have a bare silver top Zetec. There is a black top ecu and all keys etc, would this work on my silver top??
http://www.locostbuilders.co.uk/forum/34/viewthread.php?tid=208003
chris
posted on 7/3/17 at 09:11 AM Reply With Quote
The only difference between black top and silver top is tappets and water pump so any electronics between the two should work
Ugg10
posted on 7/3/17 at 09:53 AM Reply With Quote
Iirc you also need the right injectors and maf to go with the ecu and also a lambda sensor in the exhaust. I could be wrong though and they are interchangeable but had problems between swapping 1800 and 2000 silvertop parts before.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
the_big_1
posted on 7/3/17 at 09:56 AM Reply With Quote
Cheers guys. I have a brand new inlet manifold off a black top that has the injectors etc
posted on 7/3/17 at 11:15 AM Reply With Quote
Silverton engine sensors don't work with blacktop ecu either, you'll need to change all the electronics over.
the_big_1
posted on 7/3/17 at 11:17 AM Reply With Quote
Only ones would be crank and cam sensors?
posted on 7/3/17 at 11:21 AM Reply With Quote
Crank, cam temp and as said all the bits on the inlet which you already have...
the_big_1
posted on 7/3/17 at 11:24 AM Reply With Quote
Sounds good to me. Sensors should be fine to get online.
