Author: Subject: Universal Type Engine and Gearbox Mounts
BigDawgV8
posted on 8/11/20 at 09:32 AM Reply With Quote
Morning All!
I’m almost ready to fit the engine and gearbox into my project. Ford Zetec with Mazda ‘box.
The last time, I used some universal type engine and gearbox mounts from a now defunct hot-rod supplier.
Is there somewhere else that I can buy them from?
Recommendations appreciated.
Thanks!
big_wasa
posted on 8/11/20 at 10:45 AM Reply With Quote
What Mazda box ?
There is a guy called Lee Butcher that makes an adjustable mount for the Rx8 box.
There are a few guys that make Engine side plates.
CosKev3
posted on 11/11/20 at 08:07 PM Reply With Quote
I've used round poly engine mounts,think they are land rover ones.
For the gearbox one I drilled and tapped the underside of the box,fitted a helical into it then the mount screws straight into bottom of box.
So then you just need to make a mount plate up to go between the chassis in tunnel.
I used 3mm plate,then welded that into chassis.
CosKev3
posted on 11/11/20 at 08:08 PM Reply With Quote
https://www.ebay.co.uk/itm/252969013861
